CB550K3 rebuild - spare spring?
Topic: CB550K3 rebuild - spare spring? (Read 7157 times)
Bookmark1
Newbie
March 13, 2023, 02:46:08 PM »
Does anyone recognise where this flimsy little spring may have come from - it seems to be left over on my CB550K3 rebuild.
McCabe-Thiele (Ted)
Re: CB550K3 rebuild - spare spring?
March 13, 2023, 03:23:00 PM »
Looks a bit like a rocker shaft spring - hard to tell the diameter in the photo.
Link to my full restoration
Oddjob
March 13, 2023, 03:44:20 PM »
Steering lock spring?
It might also be off the carbs especially if they are still the dreaded PD carbs, more springs than a mattress those carbs.
Bookmark1
Newbie
March 13, 2023, 04:21:56 PM »
The spring is very loosely wound and is 12mm in diameter and 15mm in length. The actual wire is very thin, only about a mil at most. It doesn’t look as if it can be a return spring but rather some sort of spacer/cushion 🤷🏻â€â™‚ï¸
Oddjob
March 13, 2023, 04:29:15 PM »
There are springs very much like those fitted to the CB500K and CB550F carbs, they are fitted to the throttle lifter shaft. Have the carbs been apart, I'm almost certain I've seen that spring recently, just can't remember where as I've got so many parts disassembled at the moment.
McCabe-Thiele (Ted)
March 13, 2023, 04:33:56 PM »
I'm thinking steering lock spring now - have you replaced it or had it in bits?
Laverdaroo
March 13, 2023, 05:05:29 PM »
I’m with Ken on the carb springs, it’s bob on from what I can see…..
Sesman
March 13, 2023, 05:10:43 PM »
Carb lifter arm shaft spring. Thought the picture scale may be a little deceptive?
Sesman
March 13, 2023, 05:14:21 PM »
Probably stripping Nigel’s carbs Ken?
Oddjob
March 13, 2023, 05:16:27 PM »
Got 3 sets of carbs apart ATM Phil, could be any one of them, I was cleaning those springs recently to get them ready for zinc plating so it could be that's where I remember them from.
Sesman
Reply #10 on:
March 13, 2023, 05:30:11 PM »
If that spring is parallel rather than conical I’m betting it’s out of the oil filter housing…maybe.
Bookmark1
Newbie
Reply #11 on:
March 13, 2023, 06:00:03 PM »
Well done Oddjob and Ted. It is indeed from the old steering lock which I had to drill out due to there being no key. I have fitted a replacement so the spring is surplus to requirements (thank goodness).
As usual guys, many thanks for the help. This old thing is going to live again
Sesman
Reply #12 on:
March 13, 2023, 06:01:51 PM »
The bloke who’s laughing, is he the one who sold it? 😁🫣
Bookmark1
Newbie
Reply #13 on:
March 13, 2023, 07:31:58 PM »
Haha Sesman. It looks as if he’s just told me it was running when he parked it up. Truth be told this bike was written off in a very nasty accident nearly 25 years ago. My mate who owned (and crashed it) sadly passed away at the end of 2021 and the bike was found tucked away in one of his sheds. I’m trying to get most of it (it needed a new frame and crankcase housing and various other bits) back on the road as a tribute to a very good friend as I’m sure he was saving it as a retirement project.
Sesman
Reply #14 on:
March 13, 2023, 07:55:00 PM »
Glad you saw the humour. Very best of luck with the resto and keep us all informed.👍
