Author Topic: Some Minor Issues to Sort  (Read 17477 times)
Re: Some Minor Issues to Sort
« Reply #75 on: May 09, 2023, 09:26:49 PM »
It’s like ‘Painkillers Anonymous’  on here today!
🤣🤣 analgesics is a major part of us more mature riders.
« Reply #76 on: May 09, 2023, 09:38:05 PM »
Oh for me it's Betta Blockers , Calcium Channel Whatsits & Protein Pump Inhibitors plus another that made me sprout a pair of decent Man Boobs not to mention the other three.🤫🤫🤫
« Reply #77 on: May 09, 2023, 10:14:43 PM »
More like unanimous Roo!
« Reply #78 on: May 10, 2023, 02:18:09 AM »
We’re a right bunch of creaky old buggers, love it
« Reply #79 on: May 10, 2023, 07:25:43 AM »
🤣🤣🤣 if it wasn’t serious we could laugh! Maybe we need another section on this forum? Nooooo 🤭🤭
Offline Martin6
« Reply #80 on: May 10, 2023, 10:55:07 AM »
If the bearings were ever notchy they'll still be notchy but as you've loosened them off the whole of the front end will now be moving instead. Fit taper rollers is my advice.
The Hondas these days have the headstock bearings pre-tensioned when you fit them, torque the headstock adjuster ring down to 18lbs, move the headstock a few times to seat the bearings, release the pressure then re-torque to 18lbs, you then fit the top yoke and get a spring balance and hook it to the top yoke, it should take approx 2.2-3.3 ftlbs to get the top yoke to move from central, by hand this feels quite stiff if I'm honest but when the forks/wheel goes in the bars move quite freely. Most people think it's too tight and slacken off the headstock bearings but that then leaves them too loose when everything is fitted.
Can you recommend a taper bearings set? Are they simple to fit, without any machining and decent instructions?
Thanks.
« Reply #81 on: May 10, 2023, 02:54:08 PM »
I have used https://pyramid-parts.com/
Good quality make bearings at a sensible price - I would measure the height of your old bottom bearing plus any shims then check against the bottom bearing in the kit use the bottom seal & any shims in the kit to ensure you get the bottom height correct.
