Author Topic: 400/4 fuelTap Filter .  (Read 26697 times)
Offline THUNDERDOWNUNDER
« on: April 15, 2023, 07:30:43 AM »
Hi does anyone know where to get the rubber seal for the Filter assembly without buying the Whole set . Thanks .
Re: 400/4 fuelTap Filter .
« Reply #1 on: April 15, 2023, 08:06:07 AM »
IIRC if it's the round tap seal the DS kit does not have the right size O ring so they supply two thinner ones. I ended up using the original one as it was in fair condition.The only other seal iirc is a fibre washer on the Union I think.
Julie might have something suitable - not sure.
« Last Edit: April 15, 2023, 08:14:50 AM by McCabe-Thiele (Ted) »
« Reply #2 on: April 15, 2023, 08:28:58 AM »
This was my tap when I dismantled it.
.Petrol Tap by Macabe Thiele, on Flickr
« Reply #3 on: April 15, 2023, 08:55:25 AM »
Middle washer
« Reply #4 on: April 15, 2023, 09:13:00 AM »
I'd try a PM to Nurse Julie first - the replacements will probably be Vitron type. Failing that measure it up & try some suppliers.
My strainer was in bits so I bought the kit.
« Reply #5 on: April 15, 2023, 09:30:23 AM »
I have a new kit but the rubber seal has got lost . I did ask Julie but she says no .
« Reply #6 on: April 15, 2023, 12:24:03 PM »
Can you not measure the old seal or has it been binned?
« Reply #7 on: April 15, 2023, 01:13:28 PM »
Yes still have the old one but it’s very fragile . I think the size is 16 mm x 1,5mm x10 mm . The 10mm is the hole size .
« Reply #8 on: April 15, 2023, 04:02:06 PM »
Your sizes don't really add up but try some options here for size.
If they are 1.5mm wall thickness rings with an inside diameter of 10mm then the outside diameter would be 13mm.
If they are 1.5mm diameter with an outside diameter of 16mm then the inside diameter would be 13mm.
The ring shown in your diagram as 16mm o/d with 10mm i/d would be a 3mm thickness ring - this size is listed if you enter the details
I think the 16mm * 1.5 is the thread pitch.
https://www.polymax.co.uk/o-rings/rubber-viton-oring/
« Reply #9 on: April 15, 2023, 04:18:56 PM »
Yes the plastic on my mine had whole in it. Best to replace with kit if your filter is looking a bit old. Also old one could be compressed?  Hence 1.5mm.
« Reply #10 on: April 15, 2023, 04:31:05 PM »
I have an old sieve filter like that sat in it's bag unused, no idea what it's off, it's got a part number but no idea what it is off the top of my head. It was a part in my tool box when i left Queenies, even if the part number isn't correct it may be able to fit.
I'll dig it out and see what I can work out.
« Reply #11 on: April 15, 2023, 04:37:38 PM »
The O ring in my photo upper right looks very much larger than 1.5 mm diameter - long since binned.
Offline Seabeowner
« Reply #12 on: April 15, 2023, 06:51:43 PM »
It's a flat rubber washer, so the dims given are about right.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #13 on: April 15, 2023, 07:10:26 PM »
Correct, it's a flat profile. I've been having a rummage and measure up and may have found one for Rob.
« Last Edit: April 15, 2023, 08:25:19 PM by Nurse Julie »
« Reply #14 on: April 15, 2023, 07:49:39 PM »
Yes a flat washer - that's why I thought it might be a fibre one!
