General > New Member Introductions
Honda 4004
Matt_Harrington:
Getting the carbs clean and operating well will help you pin point the issue. Photos of bike? We all like a photo.....
K2-K6:
Quick and dirty check to confirm if it's actually running on all four cylinder to give you a base line, start from cold, run 20 seconds and switch off.
Then check each header pipe for temperature, spit and wet thumb method :) just to give you a reality check. Often they're not and it will still pull itself around but with similar to symptoms you described.
McCabe-Thiele (Ted):
They certainly can run very poorly when the carbs are not spot on plus the dynamic timing needs to be correct for cylinders 2 & 3 not just 1 & 4. Depends what system of electronic ignition you have if that is fixed or adjustable.
Cylinder in-balance during running can make some horrible noises - as regards running hot most probably as it's running too lean.
If the carb emulsion tubes have never been out they could well be full of dirt - easy enough to remove and clean out if you are careful. New O rings a must - did you replace the fuel strainer in the tank - worth doing imho.
Lastly have you tried removing the plugs and turning the engine with the kick start by hand to get the feel of the engine as the pistons move through the cycles - does it feel reasonably even. Try to avoid thinking the worst until the carbs are done it will feel like a different bike. I assume you did the camshaft chain tensioning adjustment - another source for noises.
K2-K6:
Don't forget the Ted special Ted :) coils fire the outer two from one coil and inner two cylinder from the other coil.
So, 1&4 fired from single coil, then 2&3 from the other single coil, not (as may seem logical to the uninitiated) one coil firing the two plugs nearest to it on one side of bike and visa versa.
Often done over the years if not familiar in fitting a new ignition setup.
Will no one ever forget my beginners blunder. ;D ;D ;D
I still marvel at the fact it got me to Ashbourne & back a couple of times as a two cylinder bike
Navigation
[0] Message Index
[*] Previous page
Go to full version
