Author Topic: Just stripped the threads on the steering stem head nut  (Read 3458 times)
Offline alexdecker
« on: June 13, 2023, 08:09:09 PM »
Torque specs seems to be waaaay too much in the manual for this nut. Around 50 lbs ft. I stripped the threads of the steering stem :( Any advice? Or is a new stem the only way to go?
Re: Just stripped the threads on the steering stem head nut
« Reply #1 on: June 13, 2023, 08:12:58 PM »
I have a good 550 steering column one that came to me foc yours for the postage cost only.
Offline alexdecker
« Reply #2 on: June 13, 2023, 09:11:01 PM »
Ted, that is so nice and generous of you. Thank you! Will write you in PM 😊
« Reply #3 on: June 13, 2023, 09:48:35 PM »
You sure it’s the stem not the nut or both?
« Reply #4 on: June 13, 2023, 10:15:00 PM »
I have stem & nut iirc.
If it's just the nut I have one  pretty sure - chrome is not perfect but all the threads on the stem are fine. Just e maim me my address is on my profile. Ted
Offline alexdecker
« Reply #5 on: June 14, 2023, 08:25:03 AM »
Just the stem actually. Just got a brand new nut :)
I have written you a PM! :)
« Reply #6 on: June 14, 2023, 09:38:52 AM »
Is your bike a 550 or a 500?
Both have the same steering shaft but difference in locks so if you fit the 550 unit in a 500 no steering lock facility as the 500 has a bottom lock. The 550 has the slot for the side lock.
« Reply #7 on: June 14, 2023, 04:16:57 PM »
Hi Ted. If that 550 unit eventually becomes a spare I’d appreciate an opportunity to buy.
« Reply #8 on: June 15, 2023, 07:47:46 AM »
Sorry Phil posted it to Alex yesterday.
