SOHC.co.uk Forums > CB350/400
Starter reduction gear
<< < (2/2)
4wDaz:
--- Quote from: Nurse Julie on July 07, 2023, 02:44:02 PM ---
--- Quote from: 4wDaz on July 07, 2023, 02:39:23 PM ---He reckons it can be done without removing the engine, so not only do you have to be a contortionist you now have to do the job lying on your back.  :o :D
--- End quote ---
If he knows so much about it, why isn't he doing it himself 🤣😏🤣🤣
--- End quote ---
;D I know i won't be attempting it  ;)
Herr Supersport:
Maybe this helps - or shows the way. Attention, it is a 550:
http://forums.sohc4.net/index.php/topic,122084.0.html#lastPost
Personally I wouldn't like to go this route. Shure you can wallpaper the entrance through the letterbox but who want's that?
4wDaz:
Thanks for that, is the 550 engine similar to the 400 apart from the cc ?
McCabe-Thiele (Ted):
I am pretty sure the sump on a 400 is smaller in terms of length & width so the aperture you are working in will be smaller as a result.
IIRC the 400 sump is a tad deeper.
4wDaz:
I wish him luck  ;D
Navigation
[0] Message Index
[*] Previous page
Go to full version
