Author Topic: My New Project arrives after a 44 year wait!  (Read 145451 times)
Re: My New Project arrives after a 44 year wait!
« Reply #180 on: April 18, 2024, 05:36:03 PM »
That’s the do dah’s Dave well done mate. Getting there now pal
« Reply #181 on: April 18, 2024, 05:40:00 PM »
My only observation about 400 carbs is anecdotal if the flooding is not when the bike has been running normally.
lf the bowls have little or no fuel in them you can get a situation where as the float bowls drop down down at an acute angle they rest against the bowl side causing a potential sticking incident.
This enables a situation where sometimes there is a jam of the valve in the 'gap' between the float bracket brassware and the valve seat  as it is out of the normal operating range/angle of seating due to the low fuel level in the bowl.
The above jam is such that even thought the petrol is pouring into the bowl the float is unable to rise as it should as the valve is stuck in the above 'gap'.
This does not happen as an event every time my fuel is switched on after being stood for a few days or drained over winter.
I have just rocked the bike from side to side whist astride my 400 this causes the flooding to stop pretty much immediately after any petrol in the overflow pipe has run out.
I suspect it is linked to the brassware attached to the float and possibly previous attempts to adjust the float level.
Offline Rozabikes Tim
« Reply #182 on: April 18, 2024, 08:12:57 PM »
Peter Horton refurbished the original clocks including converting the rev counter to a suitable 400/4 item from the 250 rev counter that was on the bike. They look fantastic and I asked Peter to put the MPH/KPH face on the speedo for no other reason than I like them :-).
This morning I collected the finished paint set from Tony at Cyclesprays in Horsham, Sussex. He has done a marvelous job considering the tank I took to him! He placed the decals on the tank (decals supplied by Piki (Reddice) on here) and clear coated them with the same on the side panels. I'll decide it I want to put the saving lives sticker above the fuel tank, I don't really like the look of it!
I went to refit the carbs yesterday but thought I'd bench test them first with fuel to check the floats, of course one leaked really badly (No 1). A frustrating three hours spent adjusting the float and re-testing got me nowhere and it looks like I'll have to fit one of the new Keyster float valves to replace the original as the tip looks worn. What is it about 400/4 carbs, they work fine one minute and flood the next!
Next job will be to fit the carbs and handlebars with the switches.
That's so fast Dave,  just sitting on the table in such a yellow way!!
Seriously top job on the paint - local guy to you?
« Reply #183 on: April 18, 2024, 08:34:06 PM »
Great work on the clocks and paintwork.  Lovely job.
The bike will be up and running in no time. 😎
« Reply #184 on: April 19, 2024, 09:19:46 AM »
I mounted the carbs in the workmate and made sure they were on the level. Frantic tapping of the bowl did nothing to free a sticking float (if that's what it was). Looking at the float valve needle with a pair of watchmakers glasses I can see a very slight ridge so this is probably enough to prevent the valve properly closing. I have a bag of old carb spares so I'll see if I have an old valve as fitting a full set of Keyster parts once before they all leaked!
« Last Edit: April 19, 2024, 09:36:57 AM by Laverda Dave »
« Reply #185 on: April 19, 2024, 09:36:21 AM »
🤣. Luckily the phone camera has a very fast shutter speed Tim and I was able to capture the photo despite the speed of that tank in its full yellow glory🫣.
Cycle Sprays is a 120 mile round trip for me but Tony is really good (it took him just over a week to paint everything once we had decided on the exact paint colour). I've used him a few times before and when I find someone who is good and does what they say they will do I stick with them.
To do the full paint set (two sidepanels, tank and headlight bowl including the prep (I stripped the old paint off the tank)) including applying the decals and clear coat cost £580 which to me is a good price. I could have got it done cheaper elsewhere but there's the old saying 'If you think a professional is expensive wait until you employ an amateur'. Tony is also a biker, he had his Harley V-Rod at his shop yesterday with an amazing paint job as you'd expect!
« Reply #186 on: April 19, 2024, 09:38:55 AM »
Are the moving taper part of the valve brass or rubber tip Dave ?
If brass, you could spin them in lathe and use a emery stick fine finish to dress the taper again.
« Reply #187 on: April 19, 2024, 10:12:18 AM »
They are metal tipped Nigel. I would need a suitable collet to mount them into the lathe. I tried putting them into the chuck of the Dremel but they wobbled!
I have some old genuine valves so I'll clean one up and try one of those.
« Reply #188 on: April 19, 2024, 10:40:46 AM »
Nice work there Dave on the clocks and super fast yellow bits!🤣 Always good to see bits and pieces ready for fitting.
« Reply #189 on: April 19, 2024, 10:55:53 AM »
[/quote]
I believe members here have used a mild abrasive to bed in used valves, I guess it's unlikely to work on a badly worn valve.
« Reply #190 on: April 19, 2024, 04:20:46 PM »
Dave, i have a robbed set of 400 carbs, you can have what you want for postage
« Reply #191 on: April 19, 2024, 06:00:09 PM »
Thanks for the kind offer Bryan.
I've been kept out of the man cave today as the O/H has a day off. I'll be back to restoration duties on Sunday and will try the spare valve and see how it goes. I may be in contact for bits if this plan fails😁👍.
You don't have a couple of the carb drain clips that fit to the swing arm pinch bolts do you? Happy to pay.
Dave
« Reply #192 on: April 19, 2024, 08:06:56 PM »
Not those no sorry mate, whats left ofvthe carbs is after rebuilding a mate of mines at work and comfys on here and to be honest is a load of not much, the mains just went to Roo but i know at least 1 has a float so must have needle
« Reply #193 on: May 23, 2024, 11:45:50 AM »
Time for an update on ‘Ratty’.
Well, progress has been painfully slow and has been a case recently of one step forward quickly followed by two steps back! This is the problem of buying a project bike that appears to be all there but in reality the parts in the cardboard boxes are nothing to do with the motorcycle in question! Over 50% of the parts in the boxes I found are for pushbikes! I did however find a brand new front disc so that has gone on the rebuilt front wheel after a bit of touching up of the centre section paintwork.
The real problem has been with the various nuts, bolts and washers that hold the ancillary parts such as rear taillight, indicators etc with the majority of them found to be missing or of the wrong size. The rear chain adjuster locking nuts were found to be normal thread 8mm nuts where they should be a fine pitch thread! I have now decided to go the stainless route and have been busy machining the heads of the new stainless bolts of various sizes (set screws, flanged and full length) to remove the script and to smooth them off with emery paper followed by hours on the polishing mop. I have bought Form Type C stainless washers as these are a perfect match for the OEM Honda items. These have had the polishing mop treatment as well.
Despite six months of searching trying to find a Marshall Deeptone rear silencer to bring the bike back to how I first saw it has proved elusive, I even wrote to the Jama/Laser Group in Holland who made them originally asking if they had any NOS or if they had the drawing they could give me to get one made (well you have to ask don’t you  ::)). In the end I didn’t even receive a reply :-\. I have given up on that idea and bought a new silencer from The Classic Bike Shop in Redditch. When it arrived in a double wrapped and reinforced cardboard box I put it in the loft for safe keeping.  Unfortunately when I took it out of the box on Friday to connect it up to the original header pipes that I spent a few hours bringing back to life with a wire wool, oil and a Solvol combination to remove the pitted rust I found it had a dent on the reverse cone at the end. There were no marks around the dent and it looks as though the dent was in there before the plating process. The black end plate was also really poorly painted as though whoever painted it used a rattle can and didn’t shake it beforehand! I contacted Classic Bike Shop and they were brilliant, no quibbles or questions. They sent a brand new replacement on the same day by UPS and arranged for the damaged item to be collected by Royal Mail the next day. Excellent service and a big shout out to The Classic Bike Shop 8) ;D.
Has anyone used the Green Spark Plug Company to buy ND plugs? I ordered a set over a month ago and I’m still waiting! I contacted them a couple of weeks ago and was told they are waiting for the plugs to be sent from ND! It is very annoying when companies advertise items as being in stock when they plainly are not and then make the customer wait for stock to arrive. This is the first and probably last time I will use this company, I only used them because they sell ND plugs and I am wary now of buying NGK’s due to all the fakery.
The incontinent carbs have now been sorted after replacing two of the fuel valves with 'previoulsy enjoyed' items with a bit of twiddling of the seating using a bad of solvol and these are now on the bike along wiht the plenum chamber and softend rubbers supplied by Ash :).
The newly chrome plated parts really make a huge difference, Ashford Chrome Plating have done an amazing job, there is no sign of the previous bucthery inflicted on them by the PO with spotlight mountings etc. The chrome is so thick I could swim in it (where's my Speedos  :o). The chrome was actually so thick I had to chase out the threads on the rear mudguard in order to mount the rear light. I painted the underside of both guards with a zinc based paint to give them some protection and did the same with the insides of the mudguard stays, headlight rim and points cover.
So it's now onwards and upwards and at least it is getting there now. More progress as it comes in to give you a break from the election news!
« Last Edit: May 23, 2024, 12:05:14 PM by Laverda Dave »
« Reply #194 on: May 23, 2024, 12:17:22 PM »
That’s coming on Dave, lovely looking thing that, you must be chuffed?
We’re the headers good when you got the bike or have you sourced those, they look ace!
