Author Topic: Leaky fuel tap  (Read 2591 times)
Offline Athame57
    • SeaWitch Artist
Leaky fuel tap
« on: July 21, 2023, 02:44:01 PM »
It looks like I've got a leaky fuel tap, experiment ahead. With fuel line off the tap was dripping even in the off position. Can a fuel tap actually be fixed though, paying more then £70.00 for a US spec one I'd prefer to avoid.
I brake for animals!
1978 CB400F2 named Elen.
Re: Leaky fuel tap
« Reply #1 on: July 21, 2023, 03:17:17 PM »
Depends on the type of tap.
Post a pic, some can be dismantled and some are riveted shut.
Offline Skoti
Re: Leaky fuel tap
« Reply #2 on: July 21, 2023, 03:32:09 PM »
Because the correct rubber washer was not being listed as a separate item on CMS, I instead managed to order a genuine Honda rubber valve washer from a local Honda Power Sports dealer. (sells lawn mowers and generators etc)
Beware of fitting cheapo Fleabay crap, many of them are not ethanol proof.
good luck
Skoti
Skoti
1976 Honda CB750F1
Re: Leaky fuel tap
« Reply #3 on: July 21, 2023, 03:41:50 PM »
Not sure which fuel tap you have in your 400 I assume it is.
I tried one off e-bay it was the wrong sized tank boss.
I used the DS strainer repair kit - they supply two O rings to fit instead of one in the body iirc - looking at the picture that may have changed .
My issue was mainly the filter pick up pipe  that had fallen to bits - the boss was also leaking.
« Last Edit: July 21, 2023, 03:48:19 PM by McCabe-Thiele (Ted) »
Offline Athame57
    • SeaWitch Artist
Re: Leaky fuel tap
« Reply #4 on: July 21, 2023, 04:54:43 PM »
It is this part from DSS, described as the USA F2 type because I needed that to be compatible with the tank I got from them. https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_16950KCPJ01/
Re: Leaky fuel tap
« Reply #5 on: July 21, 2023, 04:59:36 PM »
That's the rivetted up type - last time I looked there were loads of those on e-bay.  Some even cheaper than this link.
Just check the boss thread size.
https://www.ebay.co.uk/itm/195382109527?fits=UKM_StreetName%3ASuper+Four%7CUKM_Make%3AHonda&_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111314%26meid%3Dbfe7d8aa2eb04ec09cf44c905c0e6e97%26pid%3D101195%26rk%3D1%26rkt%3D12%26sd%3D184505220529%26itm%3D195382109527%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecall%26brand%3DUnbranded&_trksid=p2047675.c101195.m1851&amdata=cksum%3A195382109527bfe7d8aa2eb04ec09cf44c905c0e6e97%7Cenc%3AAQAIAAABYNaJCFP3eaFlNU%252FMPxRY0TCMczVKEUB5MsBytoCwPnd71M08lfrVO4PuTCchnU42KC4W4fZqxBROE%252BM7tSL%252BgZgL1kWiIUBRsEpydVTA61DhOJDUizwNgM7HKYQEqSaBlEI1vjZj7Zc4rrqqdU4ejTS5wLDnW1XUzOcqDILIiLpubUeyEUuwonL5nLXOpUnXZipZfwIiDcL0wlwC%252BU9rhAy%252BwvKGlUpDTYK%252FWEe807Jq%252BvOhfPKnk0tvE9XfoZo9bhRV0nUm%252FUs3WG1K15J0m3TQZXDUmnPJhVcc4RroB6dPjhqb%252Bonn5AIAuPCx1TsZOI2cycap%252BS%252Bvy%252B0scAWA7F%252FRpHWsRDOMNAgX75Vnk92t43%252FMwGQmJYUoqDyxenTBBFiMSNUzF3yKv2nQwwb5l6SUrzJSaDgGKtSm5A4Yjj94JtjdkM97URkPkxXHaeFPa1ZX2wlJAjoyRiD2pOaNpX4%253D%7Campid%3APL_CLK%7Cclp%3A2047675
« Last Edit: July 21, 2023, 05:01:46 PM by McCabe-Thiele (Ted) »
Offline Skoti
Re: Leaky fuel tap
« Reply #6 on: July 21, 2023, 05:04:25 PM »
I repaired one similar to that.
Drilled the rivets out and re-assembled with a new genuine Honda rubber sealing washer.
Drilled straight through and used M4 set screws and nylock nuts to re-assemble.
Skoti
1976 Honda CB750F1
Offline Athame57
    • SeaWitch Artist
Re: Leaky fuel tap
« Reply #7 on: July 21, 2023, 05:21:12 PM »
Thanks for the link Ted, but surely these will be UK spec, I need US spec. Unless the boss on them is also 13mm it isn't going to fit.
Re: Leaky fuel tap
« Reply #8 on: July 21, 2023, 05:30:38 PM »
I would message the seller to see of they make a 13 mm version - one I bought for my UK version was the US size that I sent back.
Re: Leaky fuel tap
« Reply #9 on: July 21, 2023, 05:45:09 PM »
If you look at the sellers other items, it looks to be a clearance warehouse or something similar. You can buy anything from a fishing rod or a pack of 12 wine bottle corks to a garden tap connector and a portable daily pill box 😂😂😂😂😂.
« Last Edit: July 21, 2023, 06:03:46 PM by McCabe-Thiele (Ted) »
Re: Leaky fuel tap
« Reply #11 on: July 21, 2023, 06:11:31 PM »
Re: Leaky fuel tap
« Reply #12 on: July 21, 2023, 09:14:07 PM »
You should be able to drill the tops off the rivets, remove the face plate and lever, remove and replace the oring inside and then retap the holes where the rivets went to fit some 3 or 4mm screws.
