Other Stuff > Misc / Open
Calliper holder pin seized
K2-K6:
--- Quote from: Multiman on July 31, 2023, 12:06:31 PM ---I did mine recently which was seized solid.
Sprayed with plusgas let overnight.
Clamped in vice and a bit of heat shifted it.
Happy to do it for you but it would probably be cheaper to take to a local garage than post it to me and back.
Roo pointed out that there should be two o-rings, above and below the bracket to help keep out the road crud.
Mine didn't have any which is probably one reason why it was seized.
91259-333-000, DSS and Fowlers have them but at nearly £5 each! plus postage.
Not sure if Julie does them.
Good luck
--- End quote ---
Interesting point about plusgas as I find that effective too. For information though, it's 90% Kerosine and 8% mineral oil if you've something big to soak and need larger quantity.
McCabe-Thiele (Ted):
Pleased to see you have sorted it George.
Multiman:
Great its sorted
Trigger:
--- Quote from: Athame57 on July 31, 2023, 02:44:14 PM ---It's out! ;D Sounds like a bad tooth don't it? The guy who did it for me with heat and some elbow grease is the same guy who welded up my split main stand for just £5.00. The job he did today for me he did for free. Well, he is a resource obviously so deserves a plug. Madeira Auto Body Repairs at the Railway Arches, Brady St. London E1. Ted, thanks for your kind offer though! :D
--- End quote ---
You can't beat a old railway arch. I had a arch Blackfriars bridge back in the good old days, all the other arches in that row did FX4 repairs. Most probably some trendy wine bar now :)
The railway arches in Derby were all demolished or bricked up after one collapsed under Friargate Station in the 1980's iirc.
There were some great firms at sensible prices.
Navigation
[0] Message Index
[*] Previous page
Go to full version
