Author Topic: Oil leak  (Read 16893 times)
Offline davefirestorm
Oil leak
« on: July 31, 2023, 09:15:48 AM »
Oil leaking from area of the front sprocket on my CB650Z Where would  I be able to buy necessary  seal/gaskets
Honda CB650Z
Honda F6C Valkyrie
Offline Matt_Harrington
Re: Oil leak
« Reply #1 on: July 31, 2023, 09:43:57 AM »
David Silvers ?
Offline SteveW
Re: Oil leak
« Reply #2 on: July 31, 2023, 09:55:59 AM »
If it’s the seal behind the front sprocket it’s a stepped seal. Only way to replace is to split the cases.
Start with the gear shift shaft seal, that’s a 20 minute job. I found that you can replace without draining the oil if you lean the bike over against a tree or something solid.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Oil leak
« Reply #3 on: July 31, 2023, 11:01:22 AM »
Hopefully it’s the easy fix ie gearbox shift shaft seal 😁 Searched and found part number for the split seal and David Silvers can supply 👍
Honda CB650Z
Honda F6C Valkyrie
