Author Topic: cb 500 but not to standard  (Read 44112 times)
Offline gary123
Re: cb 500 but not to standard
« Reply #15 on: August 02, 2023, 08:43:22 PM »
No, nothing else will be fitted until its in and yes I have a tacho seal somewhere.
« Reply #16 on: August 03, 2023, 05:54:41 AM »
Have you given up with the idea of putting a kick up hoop on the frame ?
Offline gary123
« Reply #17 on: August 03, 2023, 09:31:01 AM »
For the moment Ill leave as is. Depends on how the back end looks, I can fit a hoop if it doesn't work out.
Offline gary123
« Reply #18 on: August 15, 2023, 07:53:54 PM »
Moving along nicely. Only real issue has been lack of parts which is stretching the budget somewhat.
Im pressing on with the 550 clutch conversion but its been "challenging".
« Reply #19 on: August 15, 2023, 08:34:12 PM »
Sent you a PM mate  ;)
« Reply #20 on: August 15, 2023, 08:44:06 PM »
Here is the Free choice Gary.
Offline gary123
« Reply #21 on: August 16, 2023, 09:29:20 AM »
Black one please, see you tonight.
« Reply #22 on: August 16, 2023, 10:26:36 AM »
Do you still need the nipple ? or have you found one .
Offline gary123
« Reply #23 on: August 16, 2023, 10:54:00 AM »
Sorted the cable, thanks.
« Reply #24 on: August 16, 2023, 11:13:36 AM »
Ok mate, see you later  ;)
« Reply #25 on: August 20, 2023, 09:15:16 AM »
As discussed Gary.
Offline gary123
« Reply #26 on: August 20, 2023, 10:09:20 AM »
Thanks Julie.
« Reply #27 on: August 22, 2023, 11:06:35 PM »
Have a load of the rubbers Gary but, i have two different types at different lengths. I know one is 500/550 F1,F2  the others are 550K3 but can not remember which is which mate. Do you have the old ones to measure up ?
The two different lengths. As you can see mate, the end ones are taller .
Offline gary123
« Reply #28 on: August 23, 2023, 10:10:40 AM »
The distance from manifold to ruler edge is 24mm if this helps.
« Reply #29 on: August 23, 2023, 02:20:33 PM »
Look at the second picture and you will see the end two are slightly higher. The picture is of the middle ones that fit 2&3.
Sent you a PM mate
