Author Topic: Ignition key switch  (Read 2571 times)
Offline Pauarc
Ignition key switch
« on: August 04, 2023, 06:11:18 PM »
Is it possible to take IGNITION SWITCH apart key broken in lock
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Re: Ignition key switch
« Reply #1 on: August 04, 2023, 06:13:35 PM »
Yes, it can be taken apart. Try a good strong magnet to remove the broken part of a key  ;)
Offline Pauarc
« Reply #2 on: August 04, 2023, 06:32:02 PM »
How do you take them apart I have a couple of spare keys I would like to keep all locks the same have got lock off tried banging on rubber mate
Cb750k2
« Reply #3 on: August 04, 2023, 06:36:26 PM »
If you have the lock off, squirt a load of WD40 in the lock and bang on the edge of a wooden block . Too many ways to remove a key, including a dab of super glue on the key and attach a dowel of wood  ;)
Offline Pauarc
« Reply #4 on: August 04, 2023, 06:44:48 PM »
I will have a go in morning thanks hope it works
Cb750k2
« Reply #5 on: August 04, 2023, 08:32:49 PM »
If it's the lock that goes between the clocks that comes apart fairly easily, the one under the tank isn't so easy. Seat locks are easy to get apart.
« Reply #6 on: August 05, 2023, 07:27:42 AM »
Offline Pauarc
« Reply #7 on: August 06, 2023, 10:07:36 AM »
Got key out kept banging on wooden bench just got to put back on bike
Cb750k2
« Reply #8 on: August 06, 2023, 10:18:53 AM »
Well done. Sometimes it is the easiest solution  ;)
