Author Topic: Doms CB550F1 project  (Read 442841 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #360 on: November 12, 2023, 04:12:05 PM »
Remove the footrest rubber Dom and check to see what shape the bar is, the 500 and the 550 used different shape rods, IIRC, the 500 used square type and the 550 flat type. As the 550 uses footrest rubbers that are held by bolts going through the rubber and threaded into the bar and the 500 doesn't have that, if you swap the bars over and drill holes for the bolts unless you get them right they don't line up and the rubber sits at an angle.
This sounds far more likely to me Ken, I'll go take a look and a few photos
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #361 on: November 13, 2023, 06:09:53 PM »
Here's some pics-
1975 XS650B
« Reply #362 on: November 14, 2023, 03:57:11 AM »
Something not right there Dom. The rear brake pedal is miles too high for starters. The dot on the pedal and the dot on the rear brake actuator arm are supposed to align.
« Last Edit: November 14, 2023, 04:06:48 AM by Oddjob »
Offline DomP
« Reply #363 on: November 14, 2023, 04:14:52 PM »
Thats because I've got the rear end in bits
1975 XS650B
« Reply #364 on: November 14, 2023, 04:48:19 PM »
Try turning the peg down on the bolt
Offline DomP
« Reply #365 on: November 14, 2023, 05:41:04 PM »
In this photo you can see that it's located in the notch on the frame so won't rotate any further, the other way would be the wrong direction so i can only assume it must be the wrong peg for this bike
1975 XS650B
« Reply #366 on: November 14, 2023, 05:58:11 PM »
I am probably wrong but i seem to remember the tand on the footrest bar locating againg the frame peg that sticks out
« Reply #367 on: November 14, 2023, 06:18:34 PM »
Yeah, forgotten about that TBH Dom.
Footrest looks correct TBH. Special one fitted to the 550F due to the kickstart needing to fold right out to miss the standard 4 into 1 exhaust. It might be possible to fit the 500 footrest onto the lower bolt if you're not using the standard exhaust.
Offline DomP
« Reply #368 on: November 14, 2023, 06:50:05 PM »
Yeah that's correct Bryan
1975 XS650B
« Reply #369 on: November 14, 2023, 07:14:11 PM »
I'm pretty sure I have the same on a 550f frame. Funny flip-up peg to avoid kickstart exhausts etc. with the peg in a different location to the K models.  I assumed the foot rest was angled forward to give a sportier lean forwards towards flat bars on the F model.
« Reply #370 on: November 14, 2023, 07:35:19 PM »
I'd try a 500 footrest if it bothers you Dom. Locate it on the lower bolt, although that may mean buying the double ended bolt with it being longer. The left hand footrest is essentially the 500 so it would match better as well. You need to drill the bar to take the bolts holding the hero plate on but that's it I reckon.
Offline DomP
« Reply #371 on: November 14, 2023, 08:00:18 PM »
I thought this too until I noticed the left side
1975 XS650B
« Reply #372 on: November 14, 2023, 10:38:04 PM »
I wonder if anyone with a 550F and a 500 could try and see if the 500 footrest would fit so long as you're using an aftermarket exhaust?
Offline DomP
« Reply #373 on: November 22, 2023, 09:12:38 PM »
Not much progress lately, a bit more plating of bolts and brackets but other than that I need to paint the frame ready to get the engine back in and put together the top end.  I think for now I'm going to skip getting the camshaft reprofiled, I can always revisit that next winter.
1975 XS650B
Offline DomP
« Reply #374 on: December 03, 2023, 08:53:14 AM »
Yesterday morning I managed to drift the swing arm bushes out, the tube that runs through them had well and truly seized onto them so lots of blow torching sorted that.  What I have noticed now is that my swing arm sounds like like a child's rattle, lots of loose rust inside, how can I get it out?  It sounds solid enough when tapped so I don't think there is any terminal rot, I might drill a small hole and inject some Bilt Hamber S50
1975 XS650B
