Author Topic: 550f 069a needle position  (Read 4685 times)
Offline DomP
« on: August 19, 2023, 12:06:15 PM »
As much as I've searched I can't find an answer to which slot the needle clip should be in as stock, they are currently at no2 from top.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: 550f 069a needle position
« Reply #1 on: August 19, 2023, 12:10:50 PM »
That's correct.
Offline DomP
« Reply #2 on: August 19, 2023, 12:12:23 PM »
That's correct.
Perfect!  Let rebuilding commence
1975 XS650B
« Reply #3 on: August 19, 2023, 12:39:40 PM »
How many slots are there, iirc it's usually the middle position.
« Reply #4 on: August 19, 2023, 03:22:24 PM »
All Honda documents I have seen, agree on the 2nd from top for the CB550F.
« Reply #5 on: August 19, 2023, 04:57:00 PM »
So how many clip positions are there on your CB550 is it only four or are there five like on my 400 & presumably on my 500?
You have stated there are five on the CB500 like mine is the 550 different?
http://forums.sohc4.net/index.php?topic=109137.0
« Last Edit: August 19, 2023, 05:02:00 PM by McCabe-Thiele (Ted) »
« Reply #6 on: August 19, 2023, 07:25:28 PM »
Mine is a CB500 so five. Have a look at my overview for the rest.
« Last Edit: August 19, 2023, 07:27:29 PM by deltarider »
Offline DomP
« Reply #7 on: August 19, 2023, 07:35:21 PM »
Five slots on the needle of 069a carbs
1975 XS650B
« Reply #8 on: August 19, 2023, 07:50:58 PM »
Both the 272304 (K models) as the 273004 needle (F models) are supposed to have 5 slots.
Offline DomP
« Reply #9 on: August 20, 2023, 08:39:30 PM »
Not sure how much this clarifieus but on my cb550f all needles were set to 2nd slot and didn't appear to have ever been tempered with.
1975 XS650B
« Reply #10 on: August 21, 2023, 08:46:08 AM »
Back then, nobody did, nor would they 'adjust' the floattangs.
« Reply #11 on: August 21, 2023, 05:16:46 PM »
You clearly never went racing DR, to get maximum performance you were altering the needles, jets etc for almost every meeting due to track requirements.
