SOHC.co.uk Forums > CB350/400
Round seals and hexagon bowls...
Athame57:
--- Quote from: Oddjob on August 22, 2023, 04:09:24 PM ---Get the correct size and you don't seem to have that problem.
--- End quote ---
No, I got them to fit in the end, but it was such a pain. Julie wouldn't be sending me the wrong size btw. ;)
JezzaPeach:
Mine were much easier when I stretched them a little, plus some grease
McCabe-Thiele (Ted):
--- Quote from: Oddjob on August 22, 2023, 04:09:24 PM ---I must say the float bowl orings I tested when I was sourcing my orings for the carbs fitted with no grease or adhesive at all. Just pressed into place and stayed there. Get the correct size and you don't seem to have that problem.
--- End quote ---
That is interesting Ken, my 400 came with a lot of new parts including the float bowl rubber type seal - they fitted dry without issue - they were Keyster iirc that do not get a good press here.
When I rebuilt my spare set of 400 carbs earlier this year I had to use Red Rubber grease to hold my O ring seal in place in place.
Mikep328:
I had the same experience with the Orings as ODDjob - I got the Oring set from Nurse Julie when rebuilding my carbs a couple of weeks ago and they held themselves in the bowl grooves with no need for any grease/glue.
Athame57:
--- Quote from: Mikep328 on August 22, 2023, 06:49:18 PM ---I had the same experience with the Orings as ODDjob - I got the Oring set from Nurse Julie when rebuilding my carbs a couple of weeks ago and they held themselves in the bowl grooves with no need for any grease/glue.
--- End quote ---
Maybe I'm no good at it. ;D
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
