Author Topic: CB360 K0 Not well  (Read 7148 times)
Offline nairb
CB360 K0 Not well
« on: August 26, 2023, 07:21:54 PM »
Hello, I have had this cb360 for 3 or 4 years and after its restoration have done some 3.5 k on it without any issues....... except for now.
It starts ok and pulls off ok but now won't rev over 5k in any gear.  Seems fine in the lower revs.  SO, before I start to investigate, I thought I would ask the obvious questions......
1.  Blocked main jet?
2.  Ignition Advance not working.? Stuck.
3.  Points gone duff.  Not looked yet.
4.  Some other mysterious and daft issue.
Ta
Nairb
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
Re: CB360 K0 Not well
« Reply #1 on: August 26, 2023, 07:33:14 PM »
3.5 k is dounle the service interval for points and timing PLUS points can, and do hort out on the cover
« Reply #2 on: August 26, 2023, 07:33:22 PM »
Does it have single coil?
With twin leads?
Have you renewed it?
I had a similar issue with my CB200
turns out the primary resistance was to high,
Needed to be about 3.5 ohm
Revs OK now
Offline nairb
« Reply #3 on: August 27, 2023, 05:21:51 PM »
Well, I have begun the investigation.  Does a cb360 ever go pop.  Apparently so.
It's a twin coil/points setup.  All original as far as I know.
So a quick and simple test is to change the plugs.  And with a new set of sparkies I went for a spin.
It's still unwell.  So those points will be looked at next when it's cooled down.  Maybe a set of points from DS is in order.
Time to check the advance units as well.
« Reply #4 on: August 27, 2023, 05:26:08 PM »
If ordering points, I'd strongly advise buying original, not copies. Copies just don't seem to work as well these days.
Offline nairb
« Reply #5 on: August 27, 2023, 09:44:14 PM »
Yup. I do this with Brake cables and clutch cables as well.  Altho if DS stock an alternative, are they OK?.
Anyway..... its now being prodded to see what's wrong.
« Reply #6 on: August 27, 2023, 10:11:03 PM »
If the alternatives all there is then I suppose you have to buy them. Try and find genuine first though. Should still be some around. Ask on site and see if anyone has some stored away.
Offline nairb
« Reply #7 on: September 07, 2023, 05:09:31 PM »
An update.  Points off.  Looks ok.  Advance unit out and seems to be working.  It's free to advance and spring back.
Compression tested.  Cold engine, throttle fully open, I get about 150 (psi?) per cylinder.  So they seem ok.
All back together and points set up as manual says.  New spark plugs.
NO improvement.  Still won't rev and in holding back.  LH plug is very sooty and black.
Wonder if it's the condenser/coil.
More investigation required...........
Offline cbxman
« Reply #8 on: September 08, 2023, 08:50:11 AM »
nairb,
Have you checked the diaphragms?  Similar problem back in the day with my CB250s
Sooty plug, I would having those carbs apart.
Good Luck.  Keep us briefed
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
« Reply #9 on: September 08, 2023, 09:03:43 AM »
nairb,
Jerry
Well spotted, it does sound like that in characteristic and worthwhile checking.
If diaphragm is compromised it leaves the airline down (or below optimum height) with vacuum going really high underneath the slide it pulls fuel through the jet way in excess of target to make it like it's running on choke for that carb.
Obscure note, I use exactly this train to tune SU carbs on modified engine, thicker oil viscosity in air damper tube to cause the slide to stay below target and force rich mixture for acceleration while not having to change the main jet from optimum.  Quite a powerful effect overall.
Offline nairb
« Reply #10 on: September 08, 2023, 03:30:12 PM »
Before I spotted the info on carb diaphragms, I thought a cheap test would be to switch the coils over and see if the RH plug became very sooty.  There is only one condenser and if at fault would apply to both cylinders.
So with coils changed over and spark plugs cleaned of soot, it started fine and idles good.  But on a 2-mile run, the problem still exists - unsurprisingly.
Anyway, the LH sparky is very sooty again.  SO it's probably not the coils.....
Right, let's have a look at the LH carb......
I will report back
Offline nairb
« Reply #11 on: September 08, 2023, 04:03:40 PM »
Well the 1st prize goes to ......
Here is a pic of the LHS carb diaphragm.  Not the best pic but...
Its a hole in the diaphragm.
I hope the spare carb diaphragm is still ok
« Reply #12 on: September 08, 2023, 05:15:22 PM »
Dave Silver does a pattern part but has no stock at moment BGACC-369-004P but its £55 plus drat and postage
Offline nairb
« Reply #13 on: September 08, 2023, 05:25:38 PM »
Final report.
Spare carb diaphragm was ok and fitted.
Bike now back to its rampant best.
Good to see that DS has spares.
Nairb
« Reply #14 on: September 08, 2023, 05:28:18 PM »
CMS  has 3 original ones 16022369004 but guess what £135 plus postage.
Have you stopped gibbering yet?
