Author Topic: Batterie charging  (Read 22316 times)
Re: Batterie charging
« Reply #15 on: September 03, 2023, 08:00:02 PM »
I rate AGM batteries as the loss of charge is much slower iirc they were developed via Leisure Batteries.
On older cars you can switch battery type, Ah & CCA with impunity on more modern cars you have to update the ECU system for the charging rate to accommodate them. Might be the case with modern bikes as well.
On Wendy's Freelander  2.2 TD4 GS 13 plate I fitted an AGM battery 80 Ah 800 cca for £137 from Tanya Batteries no software update was needed. No stop start though.
That said if a vehicle is used pretty much daily the cost difference imho can't be justified just stick with standard or Gel. Over the last 10 years the cost difference has narrowed.
« Last Edit: September 03, 2023, 08:10:43 PM by McCabe-Thiele (Ted) »
Offline Matt_Harrington
« Reply #16 on: September 04, 2023, 10:04:51 AM »
Should it be of any use, I have had a few AGM batteries go flat and they are sods to charge up. I have found that putting a charges battery in parallel with the flat one fools a modern intelligent charger and it will then get charged up. Of course if you have an old charger with no intelligence and a flickering needle gauge then you will probably be OK!  ;)
