Author Topic: Honda Grease Nipples  (Read 4690 times)
Re: Honda Grease Nipples
« Reply #15 on: November 16, 2026, 04:09:13 PM »
The C90s have that same useless grease nipples fitted to the leading link suspension. At least with the normal shaped nipples you get a sporting chance. Can’t remember, think it was the last 550 I restored the central bolt that secures the swing arm was blocked from both sides. Not only the nipples but the bolt/pin internals.
« Reply #16 on: November 16, 2026, 04:46:53 PM »
Yeah it can seize the bolt Johnny as it doesn't grease the bolt with the nipple, the grease sits outside the collar and as the bolt sits inside the collar it doesn't get greased. Saying that the 500 didn't either. It's always good practice to grease the pivot bolt by hand before re-installing. The nipple has a very small ball bearing in the crown of it. These rust due to the location getting plenty of water thrown on it. I tend to buy stainless steel grease nipples these days to avoid that.
« Reply #17 on: November 16, 2026, 08:26:19 PM »
Way back when we had a small grease gun where the shaft the fitting was on went into the cylinder of grease as you pushed then came out as you released, worked really well on the Honda nipples as you were pressing square onto the nipple all the time
