SOHC.co.uk Forums > CB350/400
A very rare one from FTFF
<< < (4/4)
TrickyMicky:
--- Quote from: Oddjob on October 06, 2023, 02:12:39 PM ---Standard condition?.
Someone's drilled a hole in the headlight shell and fitted a toggle switch there, not exactly standard that.
--- End quote ---
  If you zoom in on the photo of the right side handlebar, you'll see that there is no light switch. The American models were wired to have lights on all the time, so I'm guessing that is what the toggle switch is for.
Mikep328:
Frankly, based on condition from the pics, and the fact that it is being sold in the UK but is an import from the USA, it seems dramatically overpriced to me - around £2000 too much based on my very recent experience looking for and purchasing one... ;)
Orcade-Ian:
Exactly Mike,
That's why I posted it.  When you look closely at some parts, they need some work - either replacing, re-chroming or polishing.  Looks like it's had a drop on the left side - alternator casing and badge,  the points cover has a ding, the brake pedal and gear lever need attention as do the fork sliders.  If you do all of that, then it's just another restored import with an unverifiable mileage.  Admittedly a very nice bike but not at that money.
Ian
Oddjob:
I thought it had been dropped on the rotor cover as well Ian but closer inspection showed it as just lacquer peeling and alloy corrosion. Same type of corrosion on the fork sliders, just age and possibly a slightly damp storage environment.
Orcade-Ian:
Ken,
I couldn't get close enough to properly check the rotor cover, it just looked a bit bruised - I'm 500 miles from you and even further from the bike🤡
Ian
Navigation
[0] Message Index
[*] Previous page
Go to full version
