Author Topic: Changing oil...grrr!  (Read 4498 times)
Re: Changing oil...grrr!
« Reply #15 on: October 11, 2023, 03:33:17 PM »
Just thought I'd post this link.
It's a comparison of the relief valve as fitted to the DS bolt compared to the one fitted to the OE bolt.
http://www.sohc.co.uk/index.php/topic,29731.msg286903.html#msg286903.
Might be an idea to strip out the innards of the old bolt before throwing it?
Offline Mikep328
« Reply #16 on: October 11, 2023, 05:28:54 PM »
 Interesting re the difference between the pattern part spring and the OEM spring!  Of course, the actual relief pressure might be similar due to the compression of the longer, thinner spring vs the shorter, thicker OEM spring. But the OEM spring does look more "right" for the application.  ;)  Can't think of a good way to actually measure any relief pressure difference between the springs.
Maybe I'll disassemble the filter and put the original bolt back in!  I'll ponder about that...
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #17 on: October 11, 2023, 06:10:42 PM »
You could remove the setup inside the copy bolt and replace it with the setup from the OE bolt?
