SOHC.co.uk Forums > CB350/400
Diameter of the carb where the air filter rubber clamps on?
<< < (2/2)
Jan B:
Expensive but nice stacks:
http://www.steeldragonperformance.com/products_2.html
Mikep328:
Yes, those are really nice!  :)  Might be a set in my future...
teenybop1:
Those brass ones look fantastic.
McCabe-Thiele (Ted):
On exhausts you had a nice rasp from copper/ brass tail pipes I guess inlets are the same 'sumat' to do with harmonics.
TrickyMicky:
--- Quote from: McCabe-Thiele (Ted) on October 13, 2023, 02:56:23 PM ---On exhausts you had a nice rasp from copper/ brass tail pipes I guess inlets are the same 'sumat' to do with harmonics.
--- End quote ---
. Many moons ago, about 1969/70,  I bought a second hand CB250, the first of the 5 speed models. It was plagued with carb problems so I went to Read Titan in Leytonstone and purchased a pair of Amal concentrics, fitting kit, PLUS!, a nice pair of inlet bell mouths
. . This model Honda was one of the first to be equipped with a fairly loud exhaust as standard, but when the motor started to breathe properly above 7000RPM, those inlet stacks completely drowned out any other sounds. Naughty but Nice!
Navigation
[0] Message Index
[*] Previous page
Go to full version
