SOHC.co.uk Forums > CB500/550
Rusty tank restoration
Sesman:
--- Quote from: Athame57 on October 18, 2023, 08:30:16 PM ---
--- Quote from: taysidedragon on October 17, 2023, 12:29:35 PM ---I used deox-c in my tank for 24 hours and it came up really clean. 👍
--- End quote ---
What size did you need to use?
--- End quote ---
The 1kg pot is all you need….£16
taysidedragon:
--- Quote from: Sesman on October 19, 2023, 08:34:50 AM ---
--- End quote ---
--- End quote ---
--- End quote ---
Exactly. If I remember right it can make up a 20 litre solution. I didn't have a big enough container to do it in one go, so dissolved half the tub in a large clean bucket, poured it in the tank, then did the second half. Fill the tank to the brim, close the cap and leave it. Just agitate/rock the tank every now and again.
It's worth getting a large container to keep the solution in when you're finished, it can be used again several times.
Laverdaroo:
Ordered, thanks fella’s et all
Seabeowner:
Make it up as hot as possible. I used it as part three of my cleaning. Insulated the tank to keep it as hot as possible and it was all over in 5hrs.
Laverdaroo:
Good tip, cheers for that
Navigation
[0] Message Index
[*] Previous page
Go to full version
