Other Stuff
Tricks & Tips
Fork Seals 750F2 (Long with pictures) Part 1
Topic: Fork Seals 750F2 (Long with pictures) Part 1 (Read 14279 times)
PMK
SOHC Member
Destroyer of Fine Motorcycles & Idiot for Hire
August 08, 2010, 07:07:15 PM »
How to do fork seals, An idiot explains
First prop the victim up with front wheel up in the air
Then remove the front calipers by undoing these bolts (14mm Socket) on both sides
I then tend to hook the calipers up out if the way so they don't pull the hoses
Then remove the front wheel. Your bike may have a "F" on the cap, if not I tend to dot punch the fork and the cap to ensure correct orientation and side match. If look carefully you'll see them
Next undo these bolts (13mm socket) on both sides
And place the nuts and washers in a safe place
Last Edit: August 08, 2010, 07:10:35 PM by PMK
He who breaks something to see how it works has left the path of wisdom and become an engineer
Honda CB750F2 1978
Harley Sportster 883 1999
Matchless G80 1960
PMK
SOHC Member
Re: Fork Seals 750F2 (Long with pictures) Part 1
August 08, 2010, 07:16:16 PM »
Next the undo the speedo cable and drop the wheel out.
The mudguard is held with 4 bolts inside the mudguard. Mine were 10mm socket size with a lock washer and a penny washer
The mudguard will then remove toward the engine. Then undo (but not remove) the bottom pinch bolt (14mm socket)
Then the top one (10mm socket)
Then the fork leg will remove downwards to leave you with next picture
Honda CB750F2 1978
Matchless G80 1960
PMK
SOHC Member
August 08, 2010, 07:19:02 PM »
So this is what you should have about now
So we now transfer the leg to a vice or a workmate or something
Then looking up the end where the spindle lived you see this
Its a 6mm allen bolt that needs to be undone and removed
Honda CB750F2 1978
Matchless G80 1960
PMK
SOHC Member
August 08, 2010, 07:22:45 PM »
Then drain the fork leg into a suitable receptacle
On mine I had drain screws so I used them
Now pull the leg apart and you should have this
Transfer the bottom of the leg to your vice/workmate and remove the dust cover by putting a screwdriver under it and gently lifting
Last Edit: August 08, 2010, 07:26:11 PM by PMK
Honda CB750F2 1978
Matchless G80 1960
PMK
SOHC Member
August 08, 2010, 07:25:45 PM »
Next remove the C clip as shown here
All you need to do is put a screwdriver in the gap and gently lift it out
Next remove the seal the same way you did the dustcover. Then wipe the bit where the seal sits and insert the new seal.
Wrong way up
Right way up
Honda CB750F2 1978
Matchless G80 1960
PMK
SOHC Member
August 08, 2010, 07:32:18 PM »
Use the old seal to drive the new one in. Once the groove is seen replace the C clip by poking it into the groove and gently pressing it into place. Ensure it goes in all the way round with a nice click noise.
Next re-insert the leg and slide the dust cover into position, Then refit the allen screw in the base.
In the best traditions of the Haynes manual re-assembly is the reverse of dismantling. Then do the other one.
Once both seals are replaced refill with oil. To do this you need to remove the big nut at the top of the leg (23mm Socket) like this
Then fill with oil, I use a big 60ml syringe and as the F2 uses 155ml I do 2 fills of 50ml then a 55ml one.
Honda CB750F2 1978
Matchless G80 1960
PMK
SOHC Member
August 08, 2010, 07:33:57 PM »
If the seal has been leaking real bad it's always a good idea to replace the brake pads too.
Mine were salvaged with brake cleaner and a rub over with sandpaper.
Hope this helps someone
Honda CB750F2 1978
Matchless G80 1960
Spitfire
August 10, 2010, 02:58:25 PM »
Excellent work, should keep this one handy, on mine (F1) the Allen bolt in the bottom of the leg just kept turning, so I undid the big nut at the top and bunged in a couple of sockets then put the nut back on, this worked and I got the bolt out.
Den
Yoshi823
Biker to the bone...
August 10, 2010, 08:44:58 PM »
Stubborn bolts that go through the bottom of the fork leg can be undone with an air ratchet together with a bit of pressure down on the springs so's to put some weight onto the damper rod.
On another bike of mine I found a nut that fitted into the recess on the top of the damper rod, the, using an old Imperial sized 1/2" socket I welded the two together. This then meant that I was able to hold the damper rod steady while undoing the lower bolt.
It's a good idea to put a dab of blue Loctite on the thread of the lower bolt when reassembling this.
Also, before removing the fork legs from the yokes, it's a good idea to loosen the top caps on the forks, so that if you need to undo them so's to remove the springs they're already loose. The top yoke clamp nolts for the fork should be undone to do this, but leave the lower yoke clamp bolts done up.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Picasoo
Newbie
November 25, 2011, 01:17:36 PM »
Nice pics...thanks!!
bluemouse1006
SOHC Member
Reply #10 on:
February 15, 2012, 02:35:45 PM »
Great bit of info
The pictures with the seal wrong and right way round,I replaced the seals on mine prior to putting it on the road,had it MOTed today and got an advise ref the front seals damp ..... when i fitted mine I put them back as I found them.. it works out some muppett fitted the seal upside down !! so I did the same no wonder they bloody leak hey .. bought some Jap seals today Ill change the seals and make sure I fit them the correct way round this time ..
Amos
Amos
Reply #11 on:
February 15, 2012, 03:42:03 PM »
Only extra I would add is fix the pitting to the chrome with epoxy A how to exists somewhere but may be on the US site
Tomb
Reply #12 on:
February 15, 2012, 07:22:48 PM »
Can I add, if it helps (I'll get me coat if it doesn't
When doing my 500/4 seals I leave the stanchion in the yokes, remove the bottom screw and slide the slider off.
I first put the bike on the centre stand on a 2" thick piece of wood and lift the front end of the bike up to get the ground clearance to slide the slider off ........over an oil pan.
It looks possible to do this on the 750 looking at the photos, is this right??
Apart from it being easier, the other reason I don't remove the stanchions is my 500 has clip-on bars and headlamp clamps that are a pain when removing stanchions, anyone with a cafe racer style bike may have the same issues.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Other Stuff
Tricks & Tips
