Author Topic: locking petrol cap  (Read 3918 times)
Offline Stevo
locking petrol cap
« on: October 20, 2023, 04:47:36 PM »
Hello Peeps,
I am looking for help with finding a key for my 1975 cb400f super sport petrol cap, it looks like it would be some kind of hollow hex key, the tank is standard and the lock looks like a standard fitmentbut no one seems familiar with it, not even David Silver ? !
Can any of you guys shed any light on this please ?
Cheers everybody.
Steve.
PS. I will post some pics if needed.
Offline Matt_Harrington
Re: locking petrol cap
« Reply #1 on: October 20, 2023, 05:10:19 PM »
A pic would be useful
« Reply #2 on: October 20, 2023, 06:19:48 PM »
Answered on other thread.
« Reply #3 on: October 20, 2023, 07:46:50 PM »
Not Honda
« Reply #4 on: October 20, 2023, 08:40:18 PM »
This is almost certainly what you have.
And what the keys look like.
I did have a genuine Honda NOS tank lock for the 400. The lock comes with a long screw which screws into a plate on the other side of the lock after passing through the tank loops
Offline Stevo
« Reply #5 on: October 20, 2023, 09:01:40 PM »
Yes thats it,
where can I get a key dear chap ?
« Reply #6 on: October 20, 2023, 09:20:41 PM »
No offense Stevo but nowhere. No one sells these anymore. I have no idea why I have a new one myself, I did have the same lock on my 500 tank many many years ago and I had a spare key on the key ring, if I still had that key ring you'd be welcome to the key but I haven't seen that since the 80s.
You can either try and find a new one and you'd get 2 keys with that or remove and fit the proper lock like this.
https://www.cmsnl.com/products/check-assy-cap_17550377305/
« Reply #7 on: October 21, 2023, 04:38:26 AM »
The lock on my original 400/4 will open with any key!
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #8 on: October 21, 2023, 07:58:15 AM »
Ah!
Now I see! From you description I was working the other way round!  Will a 1/4" drive 6 sided socket fit down the hole?  No scale evident, so not sure what size. You could always turn or grind down the o/d and stick it on the end of a short extension bar.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #9 on: October 21, 2023, 08:24:34 AM »
Mine is the same just takes the end of the key to work.
« Reply #10 on: October 21, 2023, 09:00:43 AM »
If you find the A/F size of the Hex can't you modify a driver like in this link or a 1/4" drive socket. I would chop off the head and cut a slot in one end and braze part of and old key to it. May need the O.D machining down though. Bit of a faff but just a suggestion of what I would do.
If you did do it and it needs lathe or brazing just send me the bits and I will do it for you. You could even use an old Honda key for the handle, which would make it rather cool.
https://www.ebay.co.uk/itm/304687738310
« Last Edit: October 21, 2023, 09:04:52 AM by AshimotoK0 »
« Reply #11 on: October 21, 2023, 09:56:37 AM »
I'm sure a decent clock restorer would be able to help, at a push being able to make you one but may be cheaper to just buy a new lock if not.
« Reply #12 on: October 21, 2023, 02:15:16 PM »
Same here!
Offline Stevo
« Reply #13 on: October 21, 2023, 05:37:25 PM »
Hey ,
thanks you guys, what a lovely bunch you all are, very kind and helpful.
I really appreciate your comments, I will probably machine down a hex socket and tack a washer on the end .
Thanks again for taking the effort to help.
Cheers.
Steve.
