Author Topic: M10 DOME Cylinder NUTS HEX  (Read 71852 times)
Offline mo goldie
« on: October 31, 2023, 12:25:20 AM »
do anyone know what the thread is on the cylinder head on the black bomber...... as trying to get some to replace the old rusted  steel domed Nuts with stainless steel ones ?
I got 8 domed ones and they don't fit seems as if they are a more of course thread as I tried one and it wanted to cut a new thread so must be some other thread on the studs. if it is the ones I got they only seem to do one size of thread on Ebay so if you know where I can get some would be great help.
Mo
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Re: M10 DOME Cylinder NUTS HEX
« Reply #2 on: October 31, 2023, 08:07:02 AM »
M10 x 1.5
« Reply #3 on: October 31, 2023, 08:23:04 AM »
If that’s so Ash, then why does he say the nuts he bought have a rougher thread than the studs.?
I’m not sure what the bomber uses as I’ve never worked on one or owned one, my reply was pure logic, if the nuts he bought had a coarser thread then the studs must be metric fine and an M10 metric fine is 1.25. My logic wrong?
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #4 on: October 31, 2023, 08:59:47 AM »
I have to go with Ken on this one, OP says those nuts he bought are coarser, not finer and I have never seen or heard of an M10 coarser than 1.5mm pitch, only the 1.25mm finer version.  The domed rear damper top nuts on 350,400 and 550 fours are M10x 1.25 - I have some in stainless.  It wouldn't make engineering sense to clamp a cylinder head down with coarse threads where the wedge angle is greater and more prone to loosening.  I've never worked on a Bomber either and I've been wrong before though - just ask Christine 🤓
Ian
Just a thought - the stainless ones I bought are next size up across the flats compared with Honda - check there is clearance for your application.
« Last Edit: October 31, 2023, 10:26:29 AM by Orcade-Ian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #5 on: October 31, 2023, 10:54:06 AM »
Count ten threads on stud and then measure in mm.
1.25x10= 12.5......1.5x10=15.......well you get the picture  :) should be easily seen what pitch they are in situ.
Or try the bought nuts onto  rear shock mount to verify.
« Reply #6 on: October 31, 2023, 10:58:50 AM »
Yea you are right slapped wrist naughty boy Ash
https://www.zed-parts.com/product-page/m10-1-25-dome-nut-low-top-zinc17mm-spanner-a-f-jis
« Last Edit: October 31, 2023, 11:17:13 AM by AshimotoK0 »
« Reply #7 on: October 31, 2023, 11:06:12 AM »
Its a good bet because Soichiro was an aircraft man with many influences from that arena incorporated into the design, the "waisted head and barrel studs one of the most prominent in balance of load distribution, material elasticity and torque requirements. Fine pitch threads being an intrinsic part of accurately setting torque for such a design.  :)
« Reply #8 on: October 31, 2023, 11:08:25 AM »
As folk here will know I am always confused by Hondas metric threads so reassuring to know I am not alone.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #9 on: October 31, 2023, 11:17:59 AM »
Ah, Soichiro, my hero!
Mo,
A great asset to any restorers toolbox is a set of thread pitch gauges and if you can still get them - Zeus charts, although Mr Googly has most of that latter info these days.
I've restored many offerings from BMC and Jaguar where there is often a 'from the factory' mix of fine/coarse Metric, UNF/ UNC and even BSF/Whitworth/BA on the same car - having gauges and charts takes any guesswork out of the game.
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
« Reply #10 on: October 31, 2023, 11:23:46 AM »
All explained here:- I was getting confused with M12 which DID change from 1.5 in 1967 to 1.25 pitch.
« Last Edit: October 31, 2023, 11:25:56 AM by AshimotoK0 »
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #11 on: October 31, 2023, 11:30:34 AM »
As always,
That's great info Ash,
I just checked availability of Zeus charts and they are still about but better still, someone has published them in PDF form.  No need for jig boring coordinates (except maybe Trig - maybe that's short for trigonometry  :) ) and other pages but it's all here:
http://www.moonshiners.org.uk/MZ/zeus.pdf
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
« Reply #12 on: October 31, 2023, 02:56:56 PM »
I knew about the JIS thread bulletin Ash, hence why I mentioned the year of the bike may be of note, before 67 he may have had the old JIS threads and after he may have the modified JIS thread. I took the chance he had the new.
Glad to see we got to the bottom of it in the end, which is the priority, not how we got there.
« Reply #13 on: October 31, 2023, 04:33:50 PM »
M10 never changed though . It's M12 that's the confusing one ... e.g.  the C110 has both M10 and M12 domed nuts on the rear shock mounts and the M12 changed in '67 from 1.5 to 1.25 pitch. Another one is the M3 screw that mounted the emblems  onto 'toaster' tanks, as that changed in '67 too.
« Reply #14 on: October 31, 2023, 05:04:09 PM »
I didn't have access to the bulletin though Ash, so I made the assumption that as most of them changed it was likely that so did the M10. As it turns out that was the wrong assumption but seeing as I was possibly asking him to spend money on something I thought I'd best hedge my bets so to speak. No harm done, we got there in the end.
