Author Topic: M10 DOME Cylinder NUTS HEX  (Read 71866 times)
Offline mo goldie
Re: M10 DOME Cylinder NUTS HEX
« Reply #15 on: October 31, 2023, 09:33:31 PM »
Hi everyone
well sorry about the confusion, what I meant was that the course threads are on the studs NOT the Nuts.
and it is a 1967 Bomber and it has the course studs as I said so it must mean then that they are the 1.50
pitch threads Not 1.25, which is what i got so don`t fit but they did fit the rear shocks so used two anyway  ;D
but still looking for some 8 X 10 mm domes nuts then with a pitch of 1.50 ?
Mo
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
« Last Edit: October 31, 2023, 09:46:03 PM by AshimotoK0 »
Offline mo goldie
« Reply #17 on: October 31, 2023, 09:47:45 PM »
oh
am I right or wrong here..... is the 1.50 tread the course or the 1.25 thread ?
as they have some on Amazon and there chart say they are 1.50 pitch if they are the course thread I will get some ?
https://www.amazon.co.uk/YoiYee-Pack-M10-Dome-Nuts/dp/B0BXT7JVGN/ref=sr_1_8?keywords=m10%2Bstainless%2Bsteel%2Bdome%2Bnuts&qid=1698788361&sr=8-8&th=1
« Last Edit: October 31, 2023, 09:50:55 PM by mo goldie »
Currant BIKES:
« Reply #18 on: October 31, 2023, 11:02:01 PM »
The lower the pitch number the finer the thread.
I think of it as you need more turns with a fine thread to gain the same clamping effect.
« Reply #19 on: October 31, 2023, 11:11:10 PM »
Try these.
Middletons are very good, usually polished with no visible surface markings.
https://www.stainlessmiddleton.co.uk/32956-metric-nuts-domed
Plus most 10mm nuts will be 17mm not the usual Honda 14mm, Middletons do the right spanner size.
Offline mo goldie
« Reply #20 on: October 31, 2023, 11:16:58 PM »
are ok thanks........... but just ordered the ones from Amazon they were 10 for £4.59
so will try them should be here tomorrow  ;D
Currant BIKES:
Offline mo goldie
« Reply #21 on: November 01, 2023, 08:35:34 PM »
hi
well that was a waste of time and Money they did Not fit From Amazon... so they are Not 1.50 they must be the 1.25 thread.
Just looked on what Oddjob sent the link for and it was Not clear...... is it 10 for £12.95 or for One ?  :-[
Must be a walking bank I think ha  ;D
Currant BIKES:
Offline mo goldie
« Reply #22 on: November 01, 2023, 08:57:44 PM »
are here we go again  ;D
just found a company called MrMegapack and got 10 X M10 X 1.25 pitch .....please be right this time my wallet can`t stand No more  ;D
Currant BIKES:
« Reply #23 on: November 01, 2023, 09:14:49 PM »
Try these.
As an aside Ken, have you thought about exhaust studs in Titanium, like these  https://www.ebay.co.uk/itm/114056592306 would be pretty corrosion resistant for bikes.
« Reply #24 on: November 01, 2023, 09:16:15 PM »
I don't understand.
You clearly say in post 15 that the studs thread is 1.50. Yet you go and order 1.25 nuts in your last post from Mr Megapacks.
My link was to Dave Middletons metric domed nuts page, NOT metric fine as those are another page. So those will be 1.50. No idea where you got £12.95 from, they are listed in single price. A 14mm headed domed nut, the correct spanner size BTW for a Honda, are £1.98 each, to buy 8 will cost you £23.21 inc VAT and P&P.
Middletons are NOT the cheapest out there but they are excellent quality and most importantly they are the correct spanner size, 17mm headed nuts on the cylinder head may not even fit, especially if some sit in recesses.
« Reply #25 on: November 01, 2023, 09:19:43 PM »
Try these.
I've already got stainless ones Nige, like the allen key socket feature though to fit them. The problem I found was getting them the same size as the existing studs, as in the amount of thread on both ends and the right amount of non threaded. I had to compromise a little on my fork bottom studs for instance, they were the correct length but one end had more threads on than the other. I got round it however.
« Reply #26 on: November 01, 2023, 09:28:07 PM »
Thought for the OP, put one of the bike's 8mm bolts beside the 10mm stud so that the threads interlock as that'll act like a thread gauge to tell you if its fine pitch or not.
« Reply #27 on: November 01, 2023, 10:57:52 PM »
I don't understand.
Pretty sure the 450K0 had 17mm AF nuts Ken in that location, borne out by the Service Bulletin. Someone told me that Honda UK imported a massive amount of 450's in one batch in 1966 and because the bikes were unpopular, they were still trying to get rid out of showrooms in the very early 1970's ( seem a few '72 reg's myself) so chances are the bike is pre the iso-thread change.  I still need to check my frame for the pitch of the shock mount stud. Another thing on the Bomber was that some 'ordinary' hex nuts were flat on one side and chamfered on the other.
Offline mo goldie
« Reply #28 on: November 01, 2023, 11:18:48 PM »
well what can I say I got it wrong then...........as they must be 1.25 oh well live and learn as they say.............. we all make mistakes...as the dalek said climbing off the dust bin.
we will see how them ones go ha
oh I have checked the shock mounts and they are 1.50 as the new dome nuts fit them fine  ;D
« Last Edit: November 01, 2023, 11:20:41 PM by mo goldie »
Currant BIKES:
« Reply #29 on: November 01, 2023, 11:40:15 PM »
Seems very big Ash, not like Honda at all.
Live and learn Goldie, live and learn.
