Author Topic: Motul oil  (Read 7300 times)
Re: Motul oil
« Reply #15 on: November 02, 2023, 01:04:59 PM »
On my 500 when I removed the rear lever with the tumbler type wheel (not the one at the front) I found the pivot was partly broken so fitted a new one. That said my gearshift was just a tad clunky.
Mild surface rust where it appears the bike has stood.
Only thing that stands out a bit for me though it might be normal is the poor visual match of the casings at the gearshft bearing.
Offline Pauarc
Re: Motul oil
« Reply #16 on: November 02, 2023, 04:06:28 PM »
I just looked on bike cover still off I see what you mean but the front and back line up spot on also there’s alignment Dowls I just think it’s the clutch dragging going to strip the clutch again and look at basket as Martin spotted marks on the outer
« Last Edit: November 02, 2023, 05:08:34 PM by Pauarc »
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Re: Motul oil
« Reply #17 on: November 02, 2023, 07:10:26 PM »
There are 750 members here who might help plus Trigger.
Offline Skoti
Re: Motul oil
« Reply #18 on: November 02, 2023, 07:31:36 PM »
Picture of linkage can anyone see any problems
I can't be sure from the photo, but is the spacer missing from the selector drum stopper arm, because the spring looks coil bound and over tightened?
Good luck with your fault finding
Skoti
Skoti
1976 Honda CB750F1
Offline Pauarc
Re: Motul oil
« Reply #19 on: November 02, 2023, 08:27:10 PM »
The spacer is in there  as charged stoper ring thanks Skoti
« Last Edit: November 02, 2023, 08:32:25 PM by Pauarc »
Cb750k2
Offline Martin6
Re: Motul oil
« Reply #20 on: November 02, 2023, 11:07:34 PM »
Hi Martin
Well spotted will have to check may be flash giving a shadow look at some other pictures can’t see it but  I will have to check
Thanks for your reply how’s your engine going
Paul
Paul, all back together, thanks. I'll spruce up the frame, while the engine's out. So, a bit of work to do, before my handiwork gets tested!
Offline Pauarc
Re: Motul oil
« Reply #21 on: November 07, 2023, 08:29:46 PM »
I have looked at the outer basket and it had a bit of pitting where the friction plates run I run a fine file over them also I noticed that the new friction plates had sharp edge so I filed them off have to see if that helps
Cb750k2
