SOHC.co.uk Forums > CB500/550
Front Caliper clearance.
Johnny4428:
Ken that is good advice on brake bedding in, I actually followed that routine for the K3 following a previous post you had written. I will do the same again when the weather permits. Made a considerable difference on the K3.
Oddjob:
Forgot to mention the existing brake pad transfer film on the disc surface must be removed when you fit new pads. Brake cleaner or a light sanding.
Johnny4428:
Never thought about that Ken but I see why you would do that.
McCabe-Thiele (Ted):
When I worked in the car trade not only did we give customers a written advice about bedding in disc brakes but also tyres for the first 100 miles.
I remember most new cars back in the 1960's having running in stickers in the rear windows.
Oddjob:
--- Quote from: Johnny4428 on December 20, 2023, 07:37:55 AM ---Never thought about that Ken but I see why you would do that.
--- End quote ---
I believe it's so the pad and the transfer material are the same, makes sense when you think about it. I preferred a light sanding to brake cleaner, scuffs up the disc surface as well making the bedding in process easier and faster IMO.
I remember the running in stickers as well Ted.
Navigation
[0] Message Index
[*] Previous page
Go to full version
