Any reason for this specific bolt for the brake arm?
Topic: Any reason for this specific bolt for the brake arm? (Read 5049 times)
alexdecker
SOHC Expert
February 25, 2024, 04:43:39 PM »
Hi all
Replacing some parts for the rear brake of my 550F from 1977. Just got all the parts from CMS and discovered too late that I forgot this part, and attaches the brake arm to the frame:
https://www.cmsnl.com/honda-cb550f2-super-sport-550-four-1977-european-direct-sales_model17122/bolt-stopper-arm_90133286000/
Would there be anything wrong with using a normal bolt and riding with that until my next part order? Feel like it’s a little much doing a part order for just one bolt.
Why does this need a special bolt to begin with? Just to be able to lock it with a pin? Seems to me I could just use a regular bolt the same thickness as the thick part of the original bolt? But as usual, I might be missing the bigger picture, so wanted to hear your opinion in here
- Alex
Re: Any reason for this specific bolt for the brake arm?
February 25, 2024, 05:29:09 PM »
Its a shouldered bolt so that when the nut is done up tight it can still allow the torsion arm to pivot.
You could probably get away with a collar of the right dimensions and a nylock nut
McCabe-Thiele (Ted)
February 25, 2024, 06:30:50 PM »
I agree with Bryan for a short term solution, personally I see a split pin as an essential long term safety feature.
Link to my full restoration
davidcumbria
Such great knowledge and support on here 👍
SOHC Expert
February 25, 2024, 06:43:27 PM »
If it’s like my 550 k1 it is specially shaped to locate in brake shoe holder. Also it needs a spring clip not a split pin making rear wheel removal easier. Here is a photo of the bolt. You might want to look at your backplate because a hex head wouldn’t fit - but the 500f might be different.
https://www.cmsnl.com/honda-cb550-k1-four-1975-usa_model466/bolt-rear-brake_90127323000/
Last Edit: February 25, 2024, 06:46:17 PM by davidcumbria
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own R1100GS, RD350LC YPVS , Yamaha fazer 600, Yamaha XT250, BmwR80 , HondaVT1300, Royal Alloy GT125.
McCabe-Thiele (Ted)
February 25, 2024, 06:46:26 PM »
I think were talking about two different pivots in the rear brakes.
davidcumbria
SOHC Expert
February 25, 2024, 09:32:11 PM »
Yes I’ve highlighted the brake end not the frame end.
alexdecker
SOHC Expert
February 26, 2024, 05:44:14 AM »
Thanks guys. I will try and do an intermittent solution until I make my next part order, and save a bit of money and the environment then
February 26, 2024, 07:36:47 AM »
Try your local dealer, its probaably still available
