Author Topic: Air box assembly. Got One.  (Read 11896 times)
Re: Air box assembly. Got One.
« Reply #15 on: March 04, 2024, 10:56:03 PM »
The electric switches that turn then fan on are notorious for crudding up on th GL bikes and if they are the same that could be it, they are also ,i think, in the earth side of the fan so grounding the wire should turn the fan on
« Reply #16 on: March 04, 2024, 10:59:10 PM »
Already on the list Bryan and you’re completely right on the fault, same on the VFR’s.
Apparently is a common fault across a heap of manufacturers, especially the Suzuki’s and Aprilia’s. Thanks for the heads up tjough pal.
« Reply #17 on: March 05, 2024, 03:19:39 PM »
That's a good heads up Bryan 👍
1976 Honda 400/4
« Reply #18 on: March 06, 2024, 10:25:19 PM »
combination of that so the fans working now and the thermostat was stuck open so ordered a new one today, pig to get to as its under the injector bank so had to dig deep but in a bowl of warm water, no movement............think I got it.
Cheers though Bryan, as ever, you need to remove everything to get to the bit thats shagged ;D
