Other Stuff > Misc / Open
Freeview loss of music channels
K2-K6:
Is your garage electrical supply direct off the house distribution board Ted ?
If so, you can use powerline adapters to connect via mains cabling.
Plug one into mains and connect to broadband router with Ethernet cable, then it's pair in the garage to give the out socket to use there.
McCabe-Thiele (Ted):
I've tried the Power line route but it only works on the house ring main. I have installed a hard wired Ethernet cable into my garage Annex to power my CCTV PoE security system & an old PC in there.
--- Quote from: Matt_Harrington on March 04, 2024, 05:15:40 PM ---
--- Quote from: Athame57 on March 03, 2024, 11:51:02 PM ---I havn't had a TV in many years and I don't miss it or the extortionate license fee! For free music I just love smoothradio.com , I access it from here: https://internetradiouk.com/
--- End quote ---
Actually Ted, that brings up a good idea - get a streaming device that has internet radio on it - I use Yamahas (no, not that type!) around the house (MusicCast using WiFi) but I'm sure there are many options
and providing you can get an internet signal then you have 1000'ds of stations to stream.....
--- End quote ---
Not heard of MusicCast though I do like some of the Radio 4 Dramas!
Matt_Harrington:
--- Quote from: McCabe-Thiele (Ted) on March 04, 2024, 05:40:14 PM ---I've tried the Power line route but it only works on the house ring main. I have installed a hard wired Ethernet cable into my garage Annex to power my CCTV PoE security system & an old PC in there.
--- End quote ---
Then you are almost there!
Freesat Signal now sorted bloke fitted new LNB plus he measured my Terestial TV Signal that turns out to be very good - just an issue with the frequency tuning.
Navigation
[0] Message Index
[*] Previous page
Go to full version
