Author Topic: Will it fix?  (Read 19831 times)
Will it fix?
« on: March 06, 2024, 09:10:21 PM »
Going to fit a new seal in this today but dissapointed to find this tacho drive broken. What’s the chances of a repair? Nothing to lose.
Re: Will it fix?
« Reply #1 on: March 06, 2024, 09:41:44 PM »
I don't know,
I would clean both joint surfaces with brake cleaner,
Use a good adhesive, something that lists metal,
Apply to break as per instructions,
Leave in a warm place and see what happens,
There is hardly any load on it,
If it does stick, you might want to reinforce by drilling tiny holes down through the break, fill the holes with glue and push small pins in the holes,
Re: Will it fix?
« Reply #2 on: March 06, 2024, 10:13:46 PM »
That JB Weld is pretty good.
Re: Will it fix?
« Reply #3 on: March 06, 2024, 10:35:13 PM »
They are available pattern but sit down before you check the price, all 500,550 are the same
Re: Will it fix?
« Reply #4 on: March 07, 2024, 10:24:32 AM »
Already checked Bryan!😳
Re: Will it fix?
« Reply #5 on: March 07, 2024, 10:28:28 AM »
Thanks guys for replies,  I think I might buy a replacement yet as I need one for the other engine anyway, depending what route I go for tacho/speedo set up. So I have nothing to lose by trying a repair.
Offline SteveW
Re: Will it fix?
« Reply #6 on: March 07, 2024, 10:43:34 AM »
I think Nurse Julie had a couple of these for sale recently.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Will it fix?
« Reply #7 on: March 07, 2024, 10:56:21 AM »
Thanks Steve, I will send a message to her.
Offline Orcade-Ian
    • Older Vehicle Web
Re: Will it fix?
« Reply #8 on: March 07, 2024, 10:58:20 AM »
Hi Johnny,
I'm definitely with John Webley on that one.  Some pinned reinforcement if there's space and original Araldite - not rapid version.  Leave to harden as said, somewhere warm for a few days (and then go back and collect the pieces 🙈). No, seriously it's worth a try.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: Will it fix?
« Reply #9 on: March 07, 2024, 11:01:39 AM »
Just for info, I’m currently looking into getting some made, we’ve a blank being offered soon from a pattern one that was submitted to a chsp abwhilevago. Not sure on time lines but it sounds promising.
Just so you know.
Re: Will it fix?
« Reply #10 on: March 07, 2024, 11:03:35 AM »
Yes thanks Ian, it’s a good shout indeed from John. I think I might even have some of that stuff, I’ll check to see if it is the rapid stuff or not. Thanks
Re: Will it fix?
« Reply #11 on: March 07, 2024, 11:05:17 AM »
Just so you know.
Bloody hell Roo is this an Anagram  "chsp abwhilevago"
Re: Will it fix?
« Reply #12 on: March 07, 2024, 11:05:45 AM »
Just so you know.
Thanks Roo. That’s interesting, especially if they can make them for less than £100. Keep me posted!
Re: Will it fix?
« Reply #13 on: March 07, 2024, 11:06:42 AM »
Just so you know.
Took me a wee while Ted, I got it eventually.🤪
Re: Will it fix?
« Reply #14 on: March 07, 2024, 11:11:32 AM »
Something (chsp)  a while ago ?
