Author Topic: 550 indicator relay  (Read 4904 times)
Offline DomP
550 indicator relay
« on: March 14, 2024, 05:45:17 PM »
I've bought a new 2 pin led relay for my 550 but to my surprise the one fitted to my bike is a 3 pin, I thought they were all 2 pin?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: 550 indicator relay
« Reply #1 on: March 14, 2024, 05:47:41 PM »
No, originals are 3 pin, modern day replacements are 2 pin. Just leave the green earth wire unattached.
Offline DomP
« Reply #2 on: March 14, 2024, 06:19:13 PM »
Ah thanks Julie!  I've said it before but electrics is not my strong point...pure witchcraft
1975 XS650B
« Reply #3 on: March 14, 2024, 06:42:34 PM »
IIRC you need to connect the remaining two wires the right way round as the terminal markings might be different.
I seem to recall having to reverse the two wires to get mine working - if its an electronic unit you can blow some units with the wrong polarity - worth checking the markings carefully.
With the 2-pin units they fit Positive & Negative earth vehicles  hence the need to check.
« Last Edit: March 14, 2024, 06:46:12 PM by McCabe-Thiele (Ted) »
« Reply #4 on: March 14, 2024, 06:49:35 PM »
Some of the cars still use 3 pin.
VAG (volks audi etc) relay "191" is such a beast.
« Reply #5 on: March 14, 2024, 07:01:10 PM »
Offline DomP
« Reply #6 on: March 14, 2024, 09:58:38 PM »
Mine were marked thankfully so an easy job, my cheap LED Ebay indicators work nicely too.
1975 XS650B
