CB350/400
CB750 fuel filters
Topic: CB750 fuel filters (Read 12874 times)
SeanFD
SOHC Expert
"Still running against the wind"
CB750 fuel filters
March 25, 2024, 06:34:46 PM »
Does anyone use in-line fuel filters?
If so which one and where did you get it from?
The ones I had died of old age and the ones I ordered here in France both had a hole in the gauze.
McCabe-Thiele (Ted)
Re: CB750 fuel filters
March 25, 2024, 06:35:50 PM »
I use an alloy bodied one for my 400.
Link to my full restoration
SeanFD
SOHC Expert
March 25, 2024, 06:39:55 PM »
Is it a "T" or straight through, Ted?
What's the make and source?
McCabe-Thiele (Ted)
March 25, 2024, 06:44:04 PM »
This one, I tried the see through plastic ones but they fell to bits.
They make a few different types IIRC.
https://www.ebay.co.uk/itm/173734676326
SeanFD
SOHC Expert
March 25, 2024, 07:03:55 PM »
I tried a straight one, but it doesn't work on the 750; it needs to be a 90º one.
McCabe-Thiele (Ted)
March 25, 2024, 07:08:33 PM »
Is it a space issue?
On my 400 the fuel pipe runs in a loop under the seat using a straight inline filter - not my idea a member here showed me how to route it.
Only draw back is if you run your carbs dry of fuel it takes a bit longer - not for the purists.
SeanFD
SOHC Expert
March 25, 2024, 07:20:53 PM »
Yep, space is the issue and the direction the lines have to run.
Green1
March 25, 2024, 08:01:10 PM »
Years ago my pegaso had an aluminium inline filter the sponge insert was pulled through the fuel hose about an inch one day when in the fast lane on the M11 causing fuel starvation
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
McCabe-Thiele (Ted)
March 25, 2024, 08:06:18 PM »
No Sponge in the Aeroline filters - just a rubber type sealing washer. The filter medium looks like a lump of stone like material.
There are a lot of the see through 90 deg filters out there - does someone make a decent one?
Last Edit: March 25, 2024, 08:10:03 PM by McCabe-Thiele (Ted)
SeanFD
SOHC Expert
March 25, 2024, 08:08:50 PM »
That's exactly what I was hoping to find out.
McCabe-Thiele (Ted)
Reply #10 on:
March 25, 2024, 08:11:23 PM »
Do some makes of bikes have them factory fitted?
Green1
Reply #11 on:
March 25, 2024, 08:19:55 PM »
I've never known an inline filter not cause issues. So whenever I've bought a bike with one fitted they go straight in the bin if the tank is clean
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
taysidedragon
Reply #12 on:
March 25, 2024, 08:34:50 PM »
The 400 has filter gauzes fitted inside the tank. If they are fitted and not damaged you don't need the problems caused by fitting a second filter.
Green1
Reply #13 on:
March 25, 2024, 08:42:31 PM »
Agree there should be no need for an additional filter if the fuel tap one is in place
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
CB350/400
CB750 fuel filters
