Author Topic: New to the forum  (Read 31571 times)
Offline Harriec
Re: New to the forum
« Reply #15 on: March 28, 2024, 07:21:48 PM »
So I took the rubbers off and they were all ok (in fact they look brand new). I do think they may not have been seated properly. To be honest I think I've been dealing with more than one issue.
So with those things sorted...it now runs well. It starts in the button and chokes all good. It gets warm and I have it idling nicely at about 1500rpm but as soon as I throttle it gets stuck at around 3000rpm then if I leave it it will come back down and eventually cut out. I constantly have to choke or change the idle. I'm pretty sure it's not sticky carbs as I had them out and they looked good. And the cables are aok. I replaced and set them up myself. Any ideas what else it could be?
Sorry for all the questions...you've all been very helpful!
« Reply #16 on: March 28, 2024, 07:53:38 PM »
Some considerations.
The throttle cables need to have a prescribed amount of slack, usually the "pull" one is adjusted only. A rudimentary test is to turn steering from lock to lock and blip throttle (while running) at each extreme .... any change at either end, then it needs more room to play with. I can get the spec from manual at twistgrip if you need it.
There's concise method to setup idle circuit jetting if they're been apart before, that's in manual, to get them on aim for mixture. This can get them "hanging " as described if not fully understood and implemented.
Choke should give up to about 2,750 rpm fully out, but obviously when fully home shouldn't be lifting the throttle slides at all. Also data in manual to set that correctly.
Offline Harriec
« Reply #17 on: March 28, 2024, 08:04:13 PM »
Thanks for this. I will test the throttle tomorrow and start there. I'll also look into the idle circuit set up...
« Reply #18 on: March 28, 2024, 10:09:16 PM »
As to choke the F2 is very "cold blooded" and takes quite a while before it will run off choke, again the pilot ways are notorious for clogging
Offline ozzybud
« Reply #19 on: March 28, 2024, 10:39:18 PM »
Welcome to the forum
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #20 on: March 29, 2024, 11:08:56 AM »
They are similar to your garden machinery in some effect. The adjustment screw on these carb is engine side of throttle slide and controls fuel (unlike predecessor, with air adjustment) winding out/unscrewing should bring more fuel to low speed.
Changing each one in isolation should bring about obvious shift in running for that cylinder, no response suggests impairment as way of assessment.
The aim in Honda setup routine is to bring them to borderline lean point to give combustion reference, then lift the mixture a little toward richer ( they indicate  100 rpm drop from that richer state) to get them as good for further evaluation.
If left too lean on this circuit, that forces you to then run the slides lower than ideal in controlling the tickover aim point. That can give some of the inconsistencies you've currently got.
Offline Dwilliams
  • I am currently working on a 1974 CB400F
« Reply #21 on: May 18, 2024, 08:40:02 AM »
Hello I am working on a CB400F which has worn Clutch Damper rubbers. I saw a listing on eBay a few weeks for new rubbers (which were available in 2 sizes). However the listing has now disappeared
Do any members know where I can obtain these?
Regards
Dave Williams
Liverpool
Online McCabe-Thiele (Ted)
« Reply #22 on: May 18, 2024, 11:15:29 AM »
The listing is most likely an ex- member who was indirectly driven to leave the forum - Max.
I have his email address pm me if you want it. If you send me your email address i willl forward it to Max on the understand that you do not share it to anyone without Max's consent.
Max also makes SS wheel & engine spacers for the 400 & 500s his products are excellently made.
« Last Edit: May 18, 2024, 11:42:26 AM by McCabe-Thiele (Ted) »
Offline Dwilliams
« Reply #23 on: May 18, 2024, 01:00:00 PM »
Hi Ted
Thanks for the quick response
My email is daffydlwilliams@hotmail.com
As they say mum's the word
Thanks again
Dave
« Reply #24 on: May 18, 2024, 05:39:35 PM »
I've sent you a PM. Cheers Ted
If you are unfamiliar with the site go to My Messages on the top of the web page.
« Last Edit: May 18, 2024, 07:18:31 PM by McCabe-Thiele (Ted) »
