Aligning the rear wheel on frame
Topic: Aligning the rear wheel on frame (Read 14058 times)
alexdecker
SOHC Expert
Re: Aligning the rear wheel on frame
Reply #15 on:
April 08, 2024, 04:52:32 AM »
Thanks all for your replies! I am based in Copenhagen, Denmark, so will try and find a local guy who can help me with this.
And thanks for the string method! I will do that as well, even though it doesn’t have something to do with the uneven brake feel 😊
The brake flutter is only slightly when I am driving slow and applying the brakes. Can it be that it just needs to be seated a little but more, and will disappear over time, or should I have this taken care of?
Johnwebley
Reply #16 on:
April 08, 2024, 08:41:18 AM »
The flutter, is it front brake?
Or rear?
If it is rear, remove wheel, and tyre,
After finding an engineer that can spin the whole thing in a lathe,
And get them to just remove enough to take care of the oval,
Reply #17 on:
April 08, 2024, 08:56:56 AM »
It may wear in over time as it is little but probably not, personally i would ride it using the brake as much as possible whilst investigating a machinist
