SOHC.co.uk Forums > CB750
died in the driveway
<< < (2/2)
chink1957:
Thanks for the expeditous replies.  I won't be able to get back to her until thursday, she is 26 miles away and I am stuck on Nightshift until then.  But, bye the bye, I had nothing.  I will check all of your suggestions as soon as i can and let you know what happened.  Thanks again.
Chink1957
Yoshi823:
Sounds like the ignition switch itself...i've had the same in the past.
Spitfire:
Had a similar thing happen to me on my CB750F, went to Liverpool, the bike was running great stopped at the daughters and it went as dead as a dodo, checked the fuses all OK, in the end it was the connections behind the fuses that were the problem, lots of corrosion.
Den
Dave M:
Same thing happened to me on a K6.
Turned out the contacts in the ignition switch had burnt out.
Despite being told that the switch couldn't be removed rom the lock assembly, I removed it and swapped it from an ignition I managed to get with no keys.
Worked fine after that.
chink1957:
Just a quick follow-up.  As it turned out, it was the ignition switch.  It was  replaced my my local motorcycle shop and replace the archaic fuses as well.  Again, thank you for the input.
chink1957
Navigation
[0] Message Index
[*] Previous page
Go to full version
