Author Topic: Swinging arm bushes  (Read 9797 times)
Online Bryanj
Re: Swinging arm bushes
« Reply #15 on: May 02, 2024, 08:05:44 PM »
Dave, its only the later ones with a rubber seal, early ones the seal is the felt ring, i think i still used the caps with the bronze bushings though
Offline SteveW
« Reply #16 on: May 02, 2024, 08:45:26 PM »
Mine had the felt seals, I don’t need them do I?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #17 on: May 02, 2024, 09:10:49 PM »
You don't use the felt with the bronze bushes, just the end cap.
« Reply #18 on: May 02, 2024, 09:26:44 PM »
I've been hanging around 400/4’s for too long Bryan, I thought looking at the parts diagram the end caps were the same as those on a 400. Every day is a school day on the forum👍
Offline Mike_Berkshire
« Reply #19 on: May 02, 2024, 09:39:55 PM »
Old bushes knocked out today. They were as Julie described: a sort of Bakelite material, definitely not metal. I concocted a tool to knock them out made of a length of M10 studding. Worked a treat. When it comes time to put the arm back in the frame I’m probably going to need some help. Looking at the parts diagram I don’t recall there being that many spacers and washers etc when I took it apart. Everything that came off was bagged up however,
« Reply #20 on: May 02, 2024, 10:00:53 PM »
On yours Mike, referring to the fiché picture, you only fit the new bronze bushes and the end cap.
Offline SteveW
« Reply #21 on: May 02, 2024, 10:28:18 PM »
Thanks Julie 👍
1980 CB650
1981 RD350LC
2011 Henry Hoover
