Author Topic: Swinging arm bushes  (Read 9796 times)
Offline Mike_Berkshire
Swinging arm bushes
« on: May 01, 2024, 10:10:31 AM »
Another newbie question. I am getting close to the point where I can send the frame to the paintshop for stripping/enamelling. I have taken off the swinging arm, removed the pivot bolt & the end caps. I assume that where the manual (Im mainly using Haynes) describes 'bushes' it is referring to the inner (steel?) sleeve. Having only worked on old Brit bikes previously, to me a swinging arm bush is a short brass or phosphor bronze insert. Subject to the bush sleeve being within tolerance I am planning to leave it in the swinging arm whilst it is repainted; masking the ends and the grease nipple. Is this approach OK and is my understanding of what needs to be checked for tolerance correct? Thanks
Re: Swinging arm bushes
« Reply #1 on: May 01, 2024, 10:17:31 AM »
The old ones you are referring to are like a bakolite. Cut a chanel in them and remove them before powder coating etc. Just cut lengthway with a hacksaw blade and prise out. Then cover the ends for powder coating. I sell the bronze bush replacements.
« Last Edit: May 01, 2024, 10:19:22 AM by Nurse Julie »
« Reply #2 on: May 01, 2024, 10:47:57 AM »
Thats extremely helpful and I now understand - having properly cleaned the area I can now see. So I remove the inner steel tube, cut out the old bushes, mask, paint, knock the new bushes in, put the steel tube back in, refit arm, re-fit retaining bolt, re-grease? Thanks so much! Mike
« Reply #3 on: May 01, 2024, 10:50:50 AM »
I used the bushes that Julie sells in my 400 & 500 - they are spot on.
I put the replacement bushes in the freezer overnight then drited them in with out too much difficulty.
I don't recall any removable inner steel tube, it is shown in the parts book - I obviously left mine as it was.
« Last Edit: May 01, 2024, 10:58:27 AM by McCabe-Thiele (Ted) »
Offline mickwinf
« Reply #4 on: May 01, 2024, 12:12:56 PM »
I never have much luck sawing the old bushes so made a simple tool. A thick washer the diameter of the hole in the swing arm but too big for Bush. File 2 flats on washer to allow it to pass through Bush then drop through to other side and drive Bush out with long drift. Easy! Also recommend bushes sold by Julie.
« Reply #5 on: May 01, 2024, 12:28:04 PM »
+1 with the bushes sold by Julie and Ted's top-tip re the freezer. A word of warning though, make 100% sure there is no paint on the edge of the swing arm where the top hat of the bush sits otherwise the swing arm will bind on the frame at the pivot point when you torque the pivot nut.
Offline SteveW
« Reply #6 on: May 01, 2024, 01:22:25 PM »
I heated the end of the swingarm and just knocked out the bush with a long steel rod. Came out pretty easy, no cutting.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #7 on: May 01, 2024, 04:44:13 PM »
Are you refering to the short bushes that used to be plastic (Julies are Brass) or the long Center Collar shown in the parts book diagram as item 13 p/n 52141-300-000 a hefty £103.22  from DS?
Online Bryanj
« Reply #8 on: May 01, 2024, 05:08:56 PM »
Usually you find the collar more worn than the bushes, the early one is still available, but bloody expensive, the later one is not available but you can use the early one, preferably with the bolt having a grease nipple at each end rather than the one in middle of swing arm
« Reply #9 on: May 01, 2024, 05:31:08 PM »
I’ve fitted a couple of sets also from NJ. Only advice I can offer is make sure the inside of swingarm tube is spotless. I drove mine in with a rubber mallet.
Offline SteveW
« Reply #10 on: May 01, 2024, 06:08:09 PM »
They were about 2 inches long and definitely metal.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline SteveW
« Reply #11 on: May 02, 2024, 05:39:42 PM »
I have a set of the bronze bushes from Julie I’m about to install.
Do I still need the caps, item 15 in the picture?
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #12 on: May 02, 2024, 05:51:11 PM »
Yes you do Steve. They are dust seals and they also have a rubber seal on the inside to keep the swing arm grease in.
Offline Seabeowner
« Reply #13 on: May 02, 2024, 06:55:45 PM »
That's been my experience as well. Managed to find a couple of the precision steel rods when they were cheaper.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline SteveW
« Reply #14 on: May 02, 2024, 06:59:13 PM »
Thanks Dave.
1980 CB650
1981 RD350LC
2011 Henry Hoover
