500 carbs what does what question.
3
Topic: 500 carbs what does what question. (Read 11180 times)
McCabe-Thiele (Ted)
June 07, 2024, 12:14:21 PM »
When I rebuilt the carbs on my 400 it worked out fine, runs well, no hanging throttle issues - I used the full Keyster Kit that came with the bike when I bought it from the PO. I know some folks have had issues with Keyster Kit - mine were new boxed, purchased by the PO many years ago.
Fast forward almost three years - my 500 seems to be giving me some unexpected problems - not helped by my superficial knowledge of understanding the carb design arrangement.
A bit of background is worth a mention as they were sent by the PO to Gerben so had quite nice shiney tops & bowls.
On dismantling the carbs I found one of the two bearings in the manifold mounting bracket was half broken presumably when the locking pin had been removed. I replaced the bracket with one sourced from Ken plus a much better shaft from Florence as mine was quite pitted. The four needles were set one groove lower than the centre position so the needle was effectively raised a notch - set slightly richer. One of my needles was bent near the tip - I do not belive it was bent by me but cannot be 100% certain only 99% certain it was not me. I purchased a set of 500 needles & emulsion tubes from DS as the kit was not too expensive. I have fitted the needle clips into the centre position of the five grooves on all four sliders. Carbs only bench sync at the moment.
On first start up the bike ran reasonably well but by the next day I noticed that my petrol pipe that came with my temporary tank kit was sticky on the outside. When I started the 500 the next day it was clearly not running properly on number one carb as the manifold was almost cold, plus the float valve was now leaking. I've binned the crap petrol pipe, removed the carb bowl on number one carb only & cleaned the screw in jet that had a small amount of muck in it. I opened the petrol tap with the bowl off and a bit of muck was washed out as well.
At the moment I am mentally resisting taking the carbs off - as Roo has said I need to take them off and do a proper check on the other three carbs. I'm now resigned to taking them off when I'm in the right head space. I hate having to do things twice.
I fired her up again yesterday and there was some heat on number one exhaust manifold but nothing like the other three. At the moment I have all four carbs set with the side screw 1.5 turns out. After about 5 minutes of engine running with my Stand Fan blowing air over the front of the engine I removed the spark plugs to find 2,3 & 4 all sooty.
I understand the basic principale of the main jet/slider needle - it's very similar to the old SU car designs.
I am not sure when you adjust the Brass coloured side screw what that actually does - is it just essentially for the engine idle mixture?
The other jet that screws into the carb body inside the bowl - the Pilot Jet - is the Brass coloured side screw linked to this internally?
I know we understand what a sooty plug looks like but added the photo to show how mine looked.
500 plugs
by
Macabe Thiele
, on Flickr
Last Edit: June 07, 2024, 12:17:17 PM by McCabe-Thiele (Ted)
Link to my full restoration
K2-K6
Re: 500 carbs what does what question.
June 07, 2024, 12:47:26 PM »
"I am not sure when you adjust the Brass coloured side screw what that actually does - is it just essentially for the engine idle mixture?
The other jet that screws into the carb body inside the bowl - the Pilot Jet - is the Brass coloured side screw linked to this internally?"
The idle circuit, in isolation for this description;- the small jet 40 ? Is connected to the venturi on engine side of slide to feed fuel in concise metered amount for slow running, this is given a gradient response by having an air passage from airbox side of slide into the vertical passage from float bowl to venturi through that 40 jet.
The size of that jet sets the maximum this assembly can flow, then with the external adjustment brass screw, the air passage can be controlled to alter the fuel air ratio and how quickly it gains fuel flow by changing the amount of air is allowed to pass the adjustment screw.
In effect it could be considered a small carburettor (essentially running in parallel to main slide, needle and main jet) but obviously set and fixed after adjustment to give the required fuel air mix at low air volumes in the venturi.
Effect;- if you turn the brass screw fully in, closed, there's nil air going through, the venturi drop in pressure just pulls full fuel as soon as you start the motor.
Too far turned out, there's excess air that's easier for vacuum to pull in rather than lift fuel from the float bowl.
June 07, 2024, 12:52:10 PM »
When you changed the needles you say you changed the emulsion tubes/needle jet in the carb body Ted were these Honda parts or aftermarket parts? Everybody on the US site says that the needle size and taper on "kit" parts are not the same as original and give problems.
The mixture screws on the side of the carbs are interconnected with the pilot jets, i thought there was a diagram in the Honda manual showing what went where but trouble is i dont often look in the book anymore, its all mostly in the dustbin tween me ears mate
McCabe-Thiele (Ted)
June 07, 2024, 01:18:08 PM »
The needles & emulsion tubes were from DS. I still have the old tubes & 3 needles iir.
June 07, 2024, 02:47:36 PM »
Yes but were they pattern or genuine Honda
McCabe-Thiele (Ted)
June 07, 2024, 03:12:06 PM »
They are pattern ones he sells as no Honda ones were listed- as the poor running on number one cylinder has so far been from idling is it not a bit early to suspect the DS parts?
I have also noticed the outside of plug 1 had corrosion through the outer plating so can't be certain that it's not a plug issue as well. The bike was running rich when I did my pre strip down ride with no tick over when warm unless the screw was turned up causing the hanging idle issue. I did not want to put my new plugs in only to blacken them straight away.
McCabe-Thiele (Ted)
June 08, 2024, 04:49:52 PM »
I had a chat with Ken today to gain another perspective on my carb running issues - the first thing he asked me is to confirm what the type number of my carbs were. Ken told me where to look on the right side of the main body for the type number on the main casting.
It turns out that my carbs are 069A - all four of them - apparently they were for the 550 model.
The 500 was fitted with 627B's
Looks like Gerben did one over on the PO, Ken tells me they will work on a 500 but some changes in the Main & Pilot Jet need addressing for it to run right.
If anyone here has fitted 550 carbs on a 500 with the four pipe system & standard air filter system it would be useful to know what jets they used.
One thing for certain is they will have to come off so I can sort them or if a cheap pair came up fit the right carbs.
Last Edit: June 08, 2024, 05:10:54 PM by McCabe-Thiele (Ted)
Nurse Julie
June 08, 2024, 05:59:15 PM »
Depends which air box you have fitted Ted. If you have a 500 air box you need 500 jets, 100/40, if its a 550 air box, you'll need 38/98 jets. Best to see which jets you have in them at present.
Edit.... Plus the corresponding needles and the air mix screws will be different also. One lot have a hole through them, the other lot have no hole through them.
Last Edit: June 08, 2024, 06:04:36 PM by Nurse Julie
June 08, 2024, 06:54:26 PM »
They were bought as a 500 four set from Gerben via ebay, at the time everybody was saying he is the best but not so sure now
McCabe-Thiele (Ted)
June 08, 2024, 08:04:38 PM »
Not a worry Bryan. they have cleaned up nicely.
I'm just hoping it will run okay on 550 carbs if I change some of the jetting.
Do you happen to know Bryan how the two types of Carb body differ?
Reply #10 on:
June 08, 2024, 08:10:52 PM »
I dont think they did, i undestood it was different jets for the different airbox covers, would have to spend time with the parts book doing comparisons
McCabe-Thiele (Ted)
Reply #11 on:
June 08, 2024, 08:24:25 PM »
This is my Airbox top cover arrangement.
My pilot Jets are all 40 - iirc the mains are 100.
My 500 air box
by
Macabe Thiele
, on Flickr
Reply #12 on:
June 08, 2024, 08:57:52 PM »
Thats def 500 Ted
deltarider
My kingdom for a turkey!
Reply #13 on:
June 08, 2024, 09:14:35 PM »
Here is the overview of all
oldstyle
carb settings for the CB500/550s.
McCabe-Thiele (Ted)
Reply #14 on:
June 08, 2024, 10:10:24 PM »
I'm not sure what the message is here regarding the 069A carb and the 627B differences.
Are they the same carb body but with different Jets with the markings to identify what model a carb is jetted for & made for with slightly different air screw designs - hence the difference in turn settings.
3
