Author Topic: Cb750k timing marks  (Read 6377 times)
Offline Pauarc
Cb750k timing marks
« on: July 10, 2024, 03:12:45 PM »
When timing is set to f mark and then open throttle it’s not reaching fully advance
Mark any ideas on this
This was Set with strobe light
Cb750k2
Re: Cb750k timing marks
« Reply #1 on: July 10, 2024, 04:03:53 PM »
The F mark is for static timing with a bulb not for use with a strobe
Offline Pauarc
« Reply #2 on: July 10, 2024, 04:11:26 PM »
So is it best to set at fully advanced with the strobe
« Last Edit: July 10, 2024, 04:14:17 PM by Pauarc »
Cb750k2
« Reply #3 on: July 10, 2024, 04:24:27 PM »
There should be a way of setting the timing static and if the instructions of your electronic dont give that imo they aint worth it.
As the advancers get older the springs get weak and advance starts earlier.
If you have no way of setting static timing i would put the full advance half way between the two marks for advance.
I really hate these manufacturers who dont give full and proper fitting/running instructions
« Reply #4 on: July 10, 2024, 04:44:07 PM »
My Dyna S came with full instructions  plus there are some helpful videos on U-Tube.
IIRC my instruction included static timing to get it running, I then used the strobe for dynamic timing on the 400.
Mine was fidly to get it right on 1/4 then on 2/3 as the screws were running out of adjustment so had to re-do 1/4 with the main base plate moved a tad then re-itime 1/4 again etc.
Ignore the daft intro.
. https://www.youtube.com/watch?v=uAAin68t270
« Last Edit: July 10, 2024, 05:10:34 PM by McCabe-Thiele (Ted) »
Offline Martin6
« Reply #5 on: July 10, 2024, 05:00:56 PM »
The ignition is at full advance at quite low rpm, at about 2700rpm, IIRC. So when we're riding, it is fully advanced nearly all the time.
There was a comment on the US site that it's best to think of the advancer as almost an on off switch, to retard the ignition for a stable idle. I doubt if it goes to full advance at 2300rpm say, it will make much difference out on the road. But if your advance springs are worn out, it may be advancing even lower, down at idle revs. That will lean your idle and could result in uneven idling if the advancer is moving around. I've seen mention of nipping one end of the springs off, just where the hook is formed at the end of the spring and reforming that hook. Not needed to try that, but if you have an unstable idle, that could sort it.
For my 750, having checked my advance unit is free and smooth, I don't use a strobe to time it. I static time it using one of those cheap screwdrivers with a bulb in the handle and a wire with a crocodile clip at its end. I adjust the points plate to trigger on the 'F' for 1&2. Rotate 360 degrees to check, then move on to 2&3. Adjust the points first though, as this affects the timing. 👍
« Reply #6 on: July 11, 2024, 12:18:40 PM »
Martin6, yes agree the full advance position is more important in reality.
Essentially controlling fuel burn at maximum duress and load is much more important than idle control.
Retarded position is just to facilitate easy starting and tickover speed control by retracted timing for convenience really.
Can't really see a problem with early advanced curve though, assuming no pinking, as it will improve engine torque generally if you can get it advanced as soon as possible.
I dont know why there's advice floating around to delay the advance curve by shorter springs, seems undesirable to me. Competent control of retard to ensure even tickover, yes. But other than that there's no reason to restrain in reality.
Ideally, whichever method of initial setup, then maximum advance should be checked and verified as correct as good general practice.
« Last Edit: July 11, 2024, 12:27:47 PM by K2-K6 »
« Reply #7 on: July 11, 2024, 12:55:20 PM »
Shortening springs is not to delay curve but to stop erratic advance at tickover, or at least thats the way i see it
« Reply #8 on: July 11, 2024, 01:38:19 PM »
Yes, I can see why they've tried to correct if it's obviously slack or showing advance down below about 1500 rpm but not considering it'll increase the spring rate, which will have more influence on delaying the onset of advance.
Offline cbxman
« Reply #9 on: July 11, 2024, 08:01:45 PM »
I did the cut and shut trick on my 750 advancer.  It was a little sloppy, so I put it in my pillar drill and put the tachometer on it.  I marked the bob weights with white paint and ran it up to find that it advanced too early.  I cut the spring loops as described in 'the other place' and ran the test again.  Full advance 2500rpm.
It was simple to do, but when you have only one shot at it, or mess it up and have to find another advancer.....not so easy for most of us.
So it does work, but there is likely some variability between old advancer springs..  I think it is possible to do one spring, but that might give you a two stage advance curve.  Probably wouldn't be noticeable I suspect.
Have fun!
Cheers,
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
