SOHC.co.uk Forums > SOHC Singles & Twins
Keihin jets
shifter:
Can someone tell me what thread on a keihin pilot jet as I would like to replace jet that’s broken off and have to be drilled out and tapped for a replacement .
Arch stanton:
NRP are Keyster kits.
Sesman:
Is all keyster stuff no good. I ask as I used keyster float valves and idle jets in my carb rebuild and they worked mighty fine! I didn’t contrast and compare the replacement with the originals microscopically, but the float valves do their job and the bike runs perfectly. The bike won’t take throttle when cold and on choke, but I think “they all do that sirâ€. And the bike runs perfectly off choke in less time than it takes to zip my jacket and put my lid and gloves on.
taysidedragon:
--- Quote from: Sesman on November 28, 2024, 05:06:30 PM ---Is all keyster stuff no good. I ask as I used keyster float valves and idle jets in my carb rebuild and they worked mighty fine! I didn’t contrast and compare the replacement with the originals microscopically, but the float valves do their job and the bike runs perfectly. The bike won’t take throttle when cold and on choke, but I think “they all do that sirâ€. And the bike runs perfectly off choke in less time than it takes to zip my jacket and put my lid and gloves on.
--- End quote ---
I've used Keyster on my 400f and it runs fine. There may be cheap Chinese copies about, so be careful where you buy them from.
McCabe-Thiele (Ted):
I am of the view that Keyster carb parts are much maligned, my experience with Merc parts is they can have production issues that are later fixed, that does not mean everything they produce is crap.
Easy enough to discredit a manufacturer for one batch error that was later rectified or to perpetuate problems that never existed. It's hard to disprove a negative sometimes. I have seen some manufacturers that produced poor quality parts evolve into top products (Quinten Hazel springs to mind in the 1960's) more recently Blueprint aftermarket parts.
Navigation
[0] Message Index
[*] Previous page
Go to full version
