CB750
Front Wheel/ Brake binding?
3
Topic: Front Wheel/ Brake binding? (Read 11231 times)
Martin6
SOHC Expert
Re: Front Wheel/ Brake binding?
Reply #30 on:
August 21, 2024, 09:31:07 AM »
Lòoks good. I thought about a twin disc, as the threads are there on the RH fork. What did you use for the pivot arm, as they look to be handed for the LH side only?
Johnwebley
Reply #31 on:
August 21, 2024, 09:51:10 AM »
on the 500,the pivot is handed,but if I remember its only for the adjuster screw,when I fitted my 2nd disc I simply use a countersink drill bit to modify the arm,so the screw head would fit
Martin6
SOHC Expert
Reply #32 on:
August 21, 2024, 08:31:34 PM »
Pauarc's and mine are 750s.
3
CB750
