SOHC.co.uk Forums > Project Board
Honda CB400NA Superdream - new money puddle.
<< < (60/60)
Oddjob:
£5 extra for a seal and boot seems to be a bargain.
Saying that, I was after the same sort of set for the z1000. For 4 seals, 4 orings and the dust seal and piston seal was around £45 from zpower. For all the above PLUS a new piston and a bleed nipple and cap from Cruzinimage was $25. It ended up being a buy one get one free type of deal. Plus it appeared zpower were removing the piston, the bleed nipple and its cover and charging you another £35 for the privilege of buying from them. They even had some images with Cruzinimages logo still on them. I’m not adverse to people making a profit but that’s taking the piss. I wonder if Dave Silver owns them as well.
McCabe-Thiele (Ted):
I've ordered a pair of SS caliper pistons complete with the main seals and dust seals for £45.67 incl delivery from Wemoto.
I suspect most of those for sale are branded Hedler, at one time I've ordered Hedler brand direct from ebay listings, they appear now to be a trade only wholesale internet firm.
Oddjob:
My brother in law came round on his CM400T the other day Ted. Did you know it got linked air suspension on the front forks like the CBX550?
Might be worthwhile seeing if you can find a pair of fork caps off a write off it that idea appeals to you. It has one air valve that pressurises both forks together. I found a set off a CBX550 hoping it would fit the 500 but it doesn’t.
The rear swing arm on the Superdream can rot from the inside.
Mine was showing some light rot.
I bought an as new swing arm from two wheel spares, it turned out it was for a 400T, not the 400 NA SD.
The SD forum said it would fit. I could see the damper mounts were in a different position, it was a tad longer.
When I came to fit it the swing arm I found the rear wheel was off center.
I would have needed a longer chain plus different spacers.
In the end a SD forum member who did my paintwork also did a great repair job.
Too late to return the part to two wheel spares, I also sourced the correct chromed chain guard.
Might be worth putting them on eBay. I'll stick to standard suspension Ken.
Front brakes now fitted together with newly painted front fender, brakes bled with decent lever.
All electrics connected, everything works, light switches etc.
Can't check charging as no carbs or silencer fitted as yet.
Currently polishing the left side engine cover, I thought it was ready for buffing, a couple of minutes using coarse soap says otherwise. Just spent 40 minutes using green (80 grit) plastic wheels on the poor areas. Quite pitted on the front facing edges and sides I'd forgotten how much work is needed on polishing.
Navigation
[0] Message Index
[*] Previous page
Go to full version
