SOHC.co.uk Forums > SOHC Singles & Twins
CB360 1975 Starter Motor Issue
<< < (4/4)
McCabe-Thiele (Ted):
It's a long shot but if your starter is the same as a 400N Superdream I have a good used one.
Might be worth checking the part numbers.
Superdream part number is 31200-413-780.
Bryanj:
31200 286 168 is the number for the 360 alsp seems to be the same as all the 250 and 350 twins so ought to be loads out there if needed
Madagas2002:
Hi All,
I put an earth wire to the engine from the battery negative terminal.
The bike cranked over no problem.
I then took off the engine plate which has the main earth wire.
Cleaned off some of the stove enamelling and presto it cranked over no problem.
Thank you all for your advice and help.
Kind Regards
John
Sesman:
Thanks for the feedback.
 I’d dismissed a circuit issue as you had previously stated you had checked the earth connection. Glad it’s all worked out for you.
Bryanj:
You are not the first and wont be last to be caught out by that, a nos bracket comes with no paint where the cable AND the engine case touch it
Navigation
[0] Message Index
[*] Previous page
Go to full version
