Author Topic: Throttle service  (Read 12012 times)
beardylondon
Throttle service
« on: November 17, 2024, 07:09:43 PM »
My throttle is sticking, probably just needs lube, but I just wondered if anyone has any pointers, to get it smooth, are there any serviceable parts?
Re: Throttle service
« Reply #1 on: November 17, 2024, 07:17:18 PM »
On my 400 I removed the throttle tube, cleaned it using a bottle brush with washing up liquid, dried it, then used a very light smear of Silcone grease (as used by Plumbers for mixer tap swivels) obviously cleaned the bar part as well, it's surprising how the muck accumuates. If the tube has cracked inside I would replace it. I tried Silicon Spray but the grease worked better for me.
« Last Edit: November 17, 2024, 07:19:14 PM by McCabe-Thiele (Ted) »
« Reply #2 on: November 17, 2024, 07:47:23 PM »
First find out what is causing it,
My 500 has a return spring you could tow a truck with,
Or do you have a "hanging " throttle?
That could be out of sync carbs
beardylondon
« Reply #3 on: November 17, 2024, 08:38:26 PM »
Thanks both. Symptoms are that if you turn the throttle it sometimes, not always, sticks at a higher rpm than idle. You then have to manually wiggle it and make it return to idle.
« Reply #4 on: November 17, 2024, 08:46:39 PM »
That does not sound like it's the throttle tube action, I would check the two throttle cables for correct action.
As has been mentioned by John that might be the so called "Hanging Throttle".
There is a thread on this subject, link below.
.https://www.sohc.co.uk/index.php/topic,31510.0.html
« Reply #5 on: November 17, 2024, 09:05:06 PM »
DO NOT "lube" the cables, if stiff and tight replace them
beardylondon
« Reply #6 on: November 18, 2024, 02:46:38 PM »
Thanks Bryan, this rings a bell from what someone said on the forum a while back about my speedo cable, what is the reason?
« Reply #7 on: November 18, 2024, 03:38:12 PM »
Honda cables have nylon lined outers and rubber sleeved inners so when lubed the nylon swell and the rubber gets sticky making things 10 times worse, i may have got those the wrong way round or the chemistry wrong but lubing makes them worse
beardylondon
« Reply #8 on: November 18, 2024, 08:06:08 PM »
ah ok makes sense!
I see genuine opening cable from DS are £35!  ouch
Anyone know if the pattern ones are ok?
I couldn’t see a closing cable on DS are they the same or different?
dirt cheap set on ebay, cant be any good?
https://www.ebay.co.uk/itm/186193128690?
« Last Edit: November 18, 2024, 08:14:35 PM by beardylondon »
« Reply #9 on: November 18, 2024, 08:16:18 PM »
Probably last one season so ok for price BUT do be aware they say will fit several models so probably non of them perfectly
« Reply #10 on: November 18, 2024, 08:24:24 PM »
I have fitted both cables over the last 8 years
First the pull open
Obviously a couple of months ago, the closing cable,
I think both are Slinky from Wemoto
And fit and work OK
beardylondon
« Reply #11 on: November 18, 2024, 08:59:45 PM »
Thanks for the recommendation
Offline Skoti
« Reply #12 on: November 19, 2024, 08:43:08 AM »
ah ok makes sense!
I bought cheapo cables like that and they started to fray at the carb ends after about 1500 miles. Waste of cash.
I replaced them with DS aftermarket ones which have now done over 20,000 miles and still ok, bonus is they also have nice chrome fittings at the handle bar switch end.
Skoti
1976 Honda CB750F1
beardylondon
« Reply #13 on: November 19, 2024, 09:53:10 AM »
Thanks, I’m going to go for these, made in UK, by Slinky cables
https://www.wemoto.com/parts/ac3638
https://www.wemoto.com/parts/ac3783
« Reply #14 on: November 19, 2024, 10:23:33 AM »
I lubricate cables with silicone oil, these throttle and anything else of this type, with good results.
As Ted notes, using silicone grease for the twistgrip mechanical surface is effective too.
I know it's slippery, but don't think that contributes much in the way of effort needed within the cables, it's much more that it excludes water/moisture etc over longer period to avoid and effectively eliminate corrosion.
I've not experienced any downside of doing this in affected materials as its virtually inert to those used in the cables.
Characteristics of moisture effect are white powder deposited from zinc coated cables, ultimately rust if the zinc sacrificing plate is eaten away more.
