SOHC.co.uk Forums > Anorak's Corner
TEC shocks
Spitfire:
I must admit that the Hagons definately improved my 750F1 handling compared to stock ones.
Martin6:
--- Quote from: Bryanj on December 03, 2024, 04:15:33 PM ---Only problem with Hagons, or rather Girlings as they used to be, was whilst they supplied different springs for the different models (750,550,500,400) the lengths were all the same which was not what Honda dif
--- End quote ---
My Hagons were very slightly longer (couple mm) than what I took off (originals). I thought due to sagging old springs. The bike doesn't sag anywhere near as much under its own weight. So difficult to compare. Rides well though.
McCabe-Thiele (Ted):
Strangely enough my Superdream is fitted with Hagons, nothing fancy just a normal looking damper no extra reservoirs or whatever they are called like on race bikes.
Johnwebley:
I have Hagons on my CB200
Look good, work well, quite firm,
Slight issue, they are about 2cm to long
Making it difficult to remove the wheel without the standard exhaust getting in the way,
Skoti:
Fitted Ikons with adjustable spring pre-load and damping dial adjustment.
Top notch, but needed to dig deep into my pocket.
Ikon series 7610
Model SP1296SP8
Navigation
[0] Message Index
[*] Previous page
Go to full version
