Author Topic: 1980 CB100n  (Read 9981 times)
Offline GT Graham
1980 CB100n
« on: December 09, 2024, 03:25:53 PM »
Hi I’m Graham
New here!
I have acquired a CB100n which I was told on purchase that it was running last year🤥.. after changing coil, rectify, points and plug, along with a new 6v battery I now have a spark, I have by past the fuel tank and have the carb set up on a separate fuel bottle.
It’s reluctant to start.
So am I thinking of checking the compression after checking the valve timing and all good it should start!..
is there anything I should be looking at before I go ahead?
This is new territory for me as I’ve always had 2 strokes
Graham
Re: 1980 CB100n
« Reply #1 on: December 09, 2024, 03:39:04 PM »
Blocked jets and passages in the carb
Re: 1980 CB100n
« Reply #2 on: December 09, 2024, 03:48:30 PM »
“Last year” is a minimum of 12 months sat with fuel in the carb. It will probably be sludge.
Offline GT Graham
Re: 1980 CB100n
« Reply #3 on: December 09, 2024, 04:33:23 PM »
Thank you both..
I’ll get the carb off  tomorrow and check it out… 👍
Re: 1980 CB100n
« Reply #4 on: December 09, 2024, 05:35:13 PM »
I learned to ride on a CB100 on the car park of Bedford County Council offices in 1974.
It was an RAC/ACU scheme, off road for 16 year olds. I had a Raleigh Runabout at the time.
At 17, I went for a “much more powerful” CB125S
Offline GT Graham
Re: 1980 CB100n
« Reply #5 on: December 09, 2024, 07:26:55 PM »
It’s the smallest bike I’ve owned apart from my mobylettes that I’ve have had  over the years! I still have my first Moby an AV76, which I built years ago..
The little Cb100 takes me back tho..
You maybe be able to answer this, were these little cb100cc any good? 😁
Re: 1980 CB100n
« Reply #6 on: December 09, 2024, 07:59:23 PM »
From what I recall, they were identical to the 125, but with 25cc less.
Offline GT Graham
Re: 1980 CB100n
« Reply #7 on: December 13, 2024, 05:10:41 PM »
Had a play in the shed and have had the little cb100 running, so I know now that compression is ok, even tho I have had the carb off and cleaned it it still only runs for a minute or so, so for £31.00 and postage I can get a replacement.
I recently bought some tank cleaner off Mad for bikes, has anyone used it, it says leave in the tank for several hours and shake every 30 minutes at room temperature.
Has anyone used this product? Or should I be looking at something different?
Re: 1980 CB100n
« Reply #8 on: December 13, 2024, 06:00:46 PM »
Never tried that product and have always used DEOX-C from Bilt Hamber, excellent product and does what it says on the tin.
Offline GT Graham
Re: 1980 CB100n
« Reply #9 on: December 13, 2024, 06:33:41 PM »
Thanks for that Dave
just looked it up, I will order some, plus it’s cheaper!
Graham
Re: 1980 CB100n
« Reply #10 on: December 14, 2024, 08:34:57 AM »
Plus 1 on the Deox-C.
Offline Athame57
Re: 1980 CB100n
« Reply #11 on: December 14, 2024, 12:11:59 PM »
Hello Graham
Welcome here, there's a goldmine of knowledge here to draw on too!  ;D
1978 CB400F2 named Elen.
Offline GT Graham
Re: 1980 CB100n
« Reply #12 on: December 15, 2024, 10:48:20 AM »
Thanks for the welcome.. I’m sure there is a lot of knowledge here!
Online McCabe-Thiele (Ted)
Re: 1980 CB100n
« Reply #13 on: December 15, 2024, 01:30:43 PM »
Welcome Graham, good to read you've had it running albeit briefly.
« Last Edit: December 15, 2024, 08:31:01 PM by McCabe-Thiele (Ted) »
Offline GT Graham
Re: 1980 CB100n
« Reply #14 on: December 15, 2024, 07:46:49 PM »
Thanks Ted.. a little way to go but it’s getting there
Graham
