Author Topic: Problem with horn wiring.  (Read 14425 times)
Offline ted_paper
Re: Problem with horn wiring.
« Reply #15 on: January 04, 2025, 11:00:12 AM »
Cheers guys
« Reply #16 on: January 04, 2025, 11:48:40 AM »
Turn the knob to the left till the arrow points to the white mark with 20 on it, if you connect the red lead to positive battery and black to negative battery it should show about 12v, you then leave the black on the battery and test for voltage at various points, still need to know what wires go to horn button to be exact and is the same button a headlamp flash as well
Offline ted_paper
« Reply #17 on: January 04, 2025, 12:46:32 PM »
Managed to sneak into garage for 10mins.
Reading is around 12v
Split L/H switch photos attached
« Reply #18 on: January 04, 2025, 02:27:34 PM »
Pic dont help, need to know what colour wires go to horn button
Offline Bloggs
« Reply #19 on: January 04, 2025, 05:30:50 PM »
Ted,
Where are you located? There might be someone  local to you who could help.
Michael
Online McCabe-Thiele (Ted)
« Reply #20 on: January 04, 2025, 05:38:27 PM »
Where did you take the 12v reading from?
Offline Mikep328
« Reply #21 on: January 04, 2025, 07:58:15 PM »
If there are TWO horn wires, connect the black probe to one and the red probe to the other.  Turn on the ignition and press the horn button.  You should see "battery voltage" (12-13V) on the multimeter.  You might see - (minus) voltage but that doesn't matter in this case.  It just means that you connected the red lead to the negative (earth/ground) wire instead of the hot wire.  Makes no difference for this test.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline ted_paper
« Reply #22 on: January 06, 2025, 03:08:00 PM »
Solved!
Thanks to the advice given, I traced the problem back to the spade connectors.
When trying the probes, one to the connectors seem to "wobble " a bit more than I expected so I gave it a gentle wiggle and it come off with few millimetres of wire. Did the same with the other and the same result. I managed to remove a small piece of sleeving to reveal the wires and the bulb test worked!  :)
I just need to cut back a bit more to try and extend the wires to the correct length.
The only strange thing is that both of the spade connections show signs of melting.....
Thanks for your patience and all the help given.
« Reply #23 on: January 06, 2025, 03:37:12 PM »
I’m guessing that the poor connection created a high resistance joint resulting in the production of excessive heat, which is unusual given the normal type of horn use. Oddly enough my horn connections show similar signs of heat distortion, but not to that extent.
« Reply #24 on: January 06, 2025, 04:46:03 PM »
Proximity to a hot  engine/exhaust pipes doesn't help.
« Reply #25 on: January 06, 2025, 06:18:36 PM »
Aye, certainly a possibility if not a probability.
