Author Topic: The power of bread!  (Read 29844 times)
The power of bread!
« on: January 17, 2025, 09:33:13 PM »
Thought I’d share a trick I learnt to do with bread and its power to act as a bearing removal tool where all else has failed!
I had to remove the blind gear shaft bearing from the TL125S to enable the cases to be vapour blasted. Nothing would shift the bearing and then I remembered the slice of bread trick. Basically you stuff bread into the blind bearing and tamp it down with the head of a suitable sized bolt. Keep stuffing bread into the bearing recess and eventually it will push the bearing out AND you have a handy snack when the job is done :)
Re: The power of bread!
« Reply #1 on: January 17, 2025, 10:23:03 PM »
If I hadn’t read something about this some time ago I would have been accusing you of taking the Micky Dave! 🤣  Brings a whole new meaning to using ones loaf!
« Reply #2 on: January 17, 2025, 10:33:50 PM »
 ;D ;D
I couldn't believe it when it worked Johnny ::). A brand new bearing puller for 5p ;D
« Reply #3 on: January 17, 2025, 10:37:24 PM »
Unseeded of course! Wholemeal? 😜
Offline Rozabikes Tim
« Reply #4 on: January 17, 2025, 11:31:04 PM »
Crumbs. Good job it worked the bearing must be toast now!
« Reply #5 on: January 18, 2025, 06:46:36 AM »
Awaiting Nigel’s scientific/engineering view on this.
Offline neat street
« Reply #6 on: January 18, 2025, 08:26:06 AM »
good tip,
we used to use plasticine in the old days, or blue tack.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #7 on: January 18, 2025, 10:14:21 AM »
Unbelievable, never heard of that one.
« Reply #8 on: January 18, 2025, 10:16:33 AM »
At yeast you can eat it when the job done 😁😁😁
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #9 on: January 18, 2025, 10:26:17 AM »
Back in the days when you could buy service kits for car water pumps, I bought a tin of Castrol Water pump grease - in a metal tin!  Must be the heaviest grease I've ever seen!  Still have over half of it left and I always use that to remove bearings and bushings from blind holes - particularly spigot bushes in cranks.
Good tip with the bread though and an old uncle of mine who was a plumber used to push bread into a wet pipe before soldering, so that any moisture was prevented from spoiling the joint.  When the supply was returned, the bread plug just dissolved.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline SumpMagnet
« Reply #10 on: January 18, 2025, 10:47:07 AM »
Only trouble with using this method is, if it fails..the bearing is TOAST
CB750F2 - in pieces
« Reply #11 on: January 18, 2025, 03:36:23 PM »
 ;D
Sainsburys Wholemeal Johnny although other bread bearing pullers are available  ;)
Offline MCTID
« Reply #12 on: January 18, 2025, 05:01:40 PM »
I could offer my congratulations on that splendid trick Dave, but you'd think I was just 'bettering you up' ! LOL.
You learn something new every day though.
« Reply #13 on: January 18, 2025, 10:50:41 PM »
It's a myth, the french stick I used was rubbish! ;)
« Reply #14 on: January 19, 2025, 09:34:26 AM »
All wong Roo. Use that on the build to hold things in place. Cheaper than Loctite too.
